31" Tires on a Stock TJ
Nufy:
Newb question...
Can I run 31" tires on a stock 2005 TJ ?
Looking to upgrade from a set of 215 75/r15's to 235's.
Stock TJ 15" Rims
Thanks.
hps4evr:
Generally they do fit. On stock rims they usually rub the control arms at full steering lock. Also they will probably rub the fenders if you disconnect the sway bar and are flexing off-road. On street driving is fine if you add wheel spacers or change to a rim with less backspacing.
Nufy:
Street driving mostly...
Need to replace the studded winters on my sons jeep for as little $$ as possible.
slanktapper:
TJ Rubicon comes stock with the 245 75 16 which is a 30.5x9.5 tire. The regular TJs can run them too.
Immortal:
I thought the TJ Rubis came stock with 31s.
That said, I have 31s on my stock sport with no rubbing.
Navigation
[0] Message Index
[#] Next page
Go to full version
