Author Topic: Rear Shocks - 2005 TJ...  (Read 846 times)
Offline Nufy
« on: July 17, 2018, 10:23:55 AM »
How often do the upper bolts snap when removing them ?
Difficult question to answer I guess...
I have done the fronts on my sons TJ but am wary about attempting the rears.
Its quite a difficult location to access if you snap a bolt off.
Especially from the floor of my garage without a lift...
Thanks.
Offline Jrama
Re: Rear Shocks - 2005 TJ...
« Reply #1 on: July 17, 2018, 11:59:37 AM »
They snap often, best you can do is spray them down with some sort of penetrating spray for a couple days before and re apply to make sure it soaks.
Then just turn the bolts steadily and slow.
Offline slanktapper
  • Rob
« Reply #2 on: July 17, 2018, 10:23:28 PM »
oh man i know your pain, I snapped two last fall.  What i did was lift the body up off the frame and used my air hammer to break off the nut/bolt that is stuck.
I used the flat chisel from the back then the pointed one from below until the both came out.
I had to create some interesting looking lopsided washers to bring everything flat afterwards too.
Nylocks and anti seize now
Tall Rob
Sold: Silver 06 Rubicon - 35"
Current: 92hp True selectable 4x4, Spooled rear diff, Electric front locker, 30" Mud Tires, Snorkel. Warn Axon 35s.
Offline Burrito Bill
« Reply #3 on: July 18, 2018, 03:47:08 PM »
I have always sprayed the bolts everyday for a week with PB Blaster. Out of all the shocks I have changed I have only had one break off.
01 Burrito Wagon (XJ), lots of stuff done.
Offline Sixty4X4
« Reply #4 on: August 20, 2018, 07:18:19 PM »
If you can use a oxy-acetylene torch and quickly heat the bolts up red hot then spray with water. That breaks the rust loose. Do not attempt to undo the bolt until it is cooled right down. Also throw the bolt and put a new one in.
2008 JKU Ruby, Jeep steel bumper, 9500 winch, 2016 5.3 Chev LT & 8L90 8 spd auto, 285 Maxxis Bighorns, MC 2.5" and LC Arms.
