Author Topic: Antifreeze smell...Where to start looking ?  (Read 973 times)
Offline Nufy
« on: September 06, 2018, 11:03:38 AM »
Noticing a faint smell of coolant when my sons TJ is running.
Both inside and out.  Rad levels of coolant have dropped as well over time but I can't say how much.
I assume it was full when I bought it last fall and a few weeks back I had to add about 1-2 litres to the rad to top up the level to the rad cap.
No visible leaks anywhere, no pooling etc...
Just wondering where are the common sources of leaks for a 2005 TJ 4.0 L 6 Cylinder.
Thanks.
Re: Antifreeze smell...Where to start looking ?
« Reply #1 on: September 06, 2018, 02:28:05 PM »
Check the heater core if there’s no visible leaks outside
Offline MattMan
« Reply #2 on: September 07, 2018, 12:09:14 AM »
I concur with Vince...
MattMan
Offline Kanueh
« Reply #3 on: September 07, 2018, 08:40:33 AM »
If no visible leaks are found either get it pressure tested and/or get a head gasket leak detector. Basically tests the coolant for exhaust.
2008 JKU Rubicon
Offline Nufy
« Reply #4 on: September 07, 2018, 08:47:36 AM »
No coolant in the oil as per the last oil change a few months ago...
Seems to be more from the engine bay than the interior...
Might run it up to temp tonight and take a flashlight in the dark to see if I can see anything.
Offline Kanueh
« Reply #5 on: September 07, 2018, 09:02:50 AM »
Do you see any white smoke on startup or while running from the exhaust?
2008 JKU Rubicon
Offline Nufy
« Reply #6 on: September 07, 2018, 10:12:27 AM »
No smoke in exhaust on start-up.
Offline Kanueh
« Reply #7 on: September 12, 2018, 07:22:36 AM »
Visual look for leaks, if none found pressure test it.
2008 JKU Rubicon
Offline Nufy
« Reply #8 on: October 09, 2018, 05:06:44 PM »
Found a little on the bottom tray / support of the radiator.
Tried a bottle of stop-leak for the rad but didn't work.
Where a good place to get a new rad ??
