Author Topic: Costco AGM Batteries  (Read 1287 times)
Offline Jrama
« on: March 21, 2019, 10:55:23 AM »
Just a heads up for anyone Looking for a battery soon, this might be a great option. From what  I can tell these are pretty new on the market.
For reasons that are not entirely clear to even myself (Yellow Top Still Killing it) I decided to do a dual battery setup and found these beauties. I needed the second battery to be AGM so I could mount it sideways.
$180 and a $10 Core Charge (They also have a smaller Size AGM for $160 comparable to a D35 yellow top, but for the extra $20 bucks I figured it was worth going for the biggie)
Kirkland Signature AGM Automotive Battery
Group Size: 24F AGM
Item #2070120
Up to 2X the life of a conventional SLI Battery
NONSPILLABLE, allowing for installation in nearly any position of the vehicle
Reinforced base assures performance even with high vibration
Tolerates high heat
Maintenance free
Available In-Warehouse ONLY
Warranty: 36-month Warranty with 100-month Pro Rate Included
Battery Specifications:
Cold Cranking Amps – 710
Cranking Amps – 885
Reserve Capacity – 120
Amp Hours – 70
« Last Edit: March 21, 2019, 11:09:51 AM by Jrama »
Re: Costco AGM Batteries
« Reply #1 on: March 21, 2019, 05:49:42 PM »
I saw those last week and was going to post a heads-up but I’m old and forgetful and forgot
« Reply #2 on: March 21, 2019, 07:15:23 PM »
Are these the grey ones? If so they’ve been around a few years. I had on in my yj. Needed to warranty it but will get another. Only downside is the posts are backward from the proper top post for a Jeep.
If this is a new type of agm at Costco I’ll have to check it out.
« Reply #3 on: March 22, 2019, 01:14:08 PM »
I ran my Odyssey AGM from 2010 through to 2017, and it was an absolute champ. It even gave me lots of warning when it started going downhill on me.
I can't speak for Costco brand AGM....but a good quality AGM is very much worth the money for a rig that's going offroad.
Did you install a matched pair of new AGM's Jamal?
Offline Jrama
« Reply #4 on: March 22, 2019, 02:45:29 PM »
No I didn't.....now that you mention it
What I did was use the Costco as my main starting battery/winch battery/attached to the altenator and my old yellow top as the auxiliary battery.
In between them I bought this smart isolator from Amazon which monitors both batteries voltages and disconnects and reconnects the batteries appropriately when the voltage drops on one of the batteries.
Here is a link I would be curious to hear your thoughts.
https://www.amazon.ca/FieryRed-Battery-Isolator-Voltage-Sensitive/dp/B07G6ZWM2K/ref=mp_s_a_1_5?keywords=battery+isolator&qid=1553287343&s=gateway&sr=8-5
As far as quality goes, Costco is usually pretty good but who knows...the warranty is good piece of mind at least.
« Last Edit: March 22, 2019, 02:50:23 PM by Jrama »
Offline MattMan
« Reply #5 on: March 22, 2019, 08:07:05 PM »
Good to hear... that’s what I’m running now but didn’t know anybody else that was running one.
MattMan
