Author Topic: Pinion seal, yoke holder  (Read 1047 times)
Offline GoChris
« on: March 25, 2019, 03:23:34 PM »
I am trying to replace my front pinion seal, but can't get the nut off. Does anyone have a yoke holder I could borrow so I can hopefully remove the nut?
Re: Pinion seal, yoke holder
« Reply #1 on: March 25, 2019, 05:31:15 PM »
Put the front wheels on the ground, ebrake on and in 4 low.
Are you sure you need to replace the seal?, last Summer my rear pinion started leaking badly and it turned out to be a plugged axle vent line, cleared the gunk off the end and it hasn’t leaked since
Offline GoChris
« Reply #2 on: March 25, 2019, 06:24:04 PM »
I'll check the vent line, and I had the wheels on the ground and someone standing on the brakes, no go.
« Reply #3 on: March 25, 2019, 08:21:17 PM »
You could always stick a couple of big screwdrivers or prybars through the axle u-joints
Offline Jrama
« Reply #4 on: March 25, 2019, 09:07:42 PM »
Pipe wrench on yolk it will Jam itself on the upper control arm or exhaust etc.
Used that technique many times.
« Reply #5 on: March 27, 2019, 05:29:17 PM »
X2
« Reply #6 on: March 28, 2019, 03:54:42 PM »
build a tool....
Offline Picha
« Reply #7 on: April 13, 2019, 04:04:54 AM »
Do you have to worry about breaking something if you apply too much force while doing this?
Offline Jrama
« Reply #8 on: April 16, 2019, 01:17:06 PM »
Common sense applies
