Chris is the coil 12V?
Not sure, the datasheet doesn't tell me, or I don't know how to read it.
The relay says 12VDC, 3A 125VAC
The method I'm using is the same across both links above, same pictures and writeup, just different sites.
OK, I'm not a circuit analysis kinda guy, here is a ghetto schematic of the relay, how would I wire it up???
pin#1 |o -- --o| pin #2
pin #3 |o--coil---o| pin#4
pin #5 |o ------- o| pin#6
Dang forum software is not making my spaces into spaces, anyways the schematic is on the link. I'm sure you can figure it out.
I had ign to pin #3
pin#4 jumped to pin#2
pin#2 to ground
ping #6 to sw
And I get normal flash frequency, but on dash indicators lit.
Datasheet is here
http://www.songchuan.com/PPDF/842.PDFregular 842 type
Chris
