I dont believe its the leafs that change Scott. Just the hardware that comes with their kit. The HD gets you the spanky shackles, and all the greasable hardware.
The YJ above is down to about 7 inches now between tires and flares. Pretty sure thats where it will settle out.
I think no matter what you go with, you should definately look into the same type of shackles RE is using.
That YJ up top is more stable off camber then 2 of the 4 runners we wheel with.
When you put it in perspective that Mikes tires are staying on the ground with a 94" wheelbase, and a the 135" wheelbase yota's are lifting them, it says quite a lot.
But you can really see those shackles do their thing.
That RE kit out flexes the CJ we have on 4" bds springs and tera revolvers in the rear.
Maybe Give RE a call, and see if their HD shackle set up is an option with their 2.5" springs. That would get you a bit lower, but retain some serious stability.
Just a warning though. You would need to bumpstop a lot. Mike has a 1" BL as well, and he rubs hard at full stuff.
