Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
TJ Dasboard speaker upgrade....
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: TJ Dasboard speaker upgrade.... (Read 3590 times)
Jaguar
Guest
on:
September 04, 2006, 07:22:17 PM »
I hear that there is a bracket that you can install, to put bigger speakers in to replace the smaller stock ones. Does anyone have any info on this?
Thanks guys!
Michael
Logged
fony3
UberWheeler
Reply #1 on:
September 04, 2006, 11:37:47 PM »
These plates I have found on ebay and a couple shops in the states...they allow you to up in 5 1/4 inch speakers instead of 4x6s. The advantage is better sounds in the front due to a round speaker.
Here is the ebay site:
http://cgi.ebay.ca/1997-2006-Jeep-Wrangler-speaker-adapter-plates-NR_W0QQitemZ330023375980QQihZ014QQcategoryZ14932QQrdZ1QQcmdZViewItem
If you get them let me know how they work out, since i am thinking of doing the same. I was trying to find a template and make them myself, but no luck. Suppose i could make my own template.
Logged
ramtuff
Budget Lift
Reply #2 on:
September 05, 2006, 09:12:12 AM »
try this link
http://www.jeepin.com/features/ots/index.asp
Logged
Killer Off Road Equipment
Jaguar
Guest
Reply #3 on:
September 05, 2006, 10:38:40 AM »
Awesome! thats exactly what I needed, thanks guys. I think i am going to try and just fab up those brackets. I think Lexan/Plexi glass should be strong enough... If I can find some scrap sheet metal, I'll prolly go that rout.
Thanks!
michael
Logged
ornamental
UberWheeler
speakers
Reply #4 on:
September 05, 2006, 12:27:10 PM »
ive made my own using mdf board and also made a set using some sheet metal. i would use the sheet metal as the mdf requires some shaving to fit properly.
just use the factory speaker for a template for the 2 holes on top and 2 holes below. and in a few mins you'll have your very own bracket.
for added sound quality , stuff the area around and behind the speaker with a fibre fill
Logged
murdajeep
Budget Lift
Reply #5 on:
September 26, 2006, 01:06:31 AM »
try this site.....
http://www.4wd.com/newsite/shop/productdetail.asp?pid=FNH514B&model=tj&cat=4&kid=92&catid=182&mid=n
Logged
Murdajeep
91 YJ 4.0L 3.0" Suspension Lift 1.25" Body Lift with Mickey Thompsons MTZ 33's and a champion winch, Ford 8.8, 4.10 Gears
fony3
UberWheeler
Reply #6 on:
December 12, 2006, 01:10:14 PM »
Did you ever get around to fabbing these brakets up. Just hoping to find out what you used and how it worked out.
Logged
kenny kustom
Budget Lift
Reply #7 on:
December 12, 2006, 01:22:45 PM »
http://www.clarion.com/ca/en/products/2006/audio/speakers/SRC4696/ca-en-product-pf_1138706936340.html
4 inch component set in a 4x6 plate. Sounds really good
Logged
fony3
UberWheeler
Reply #8 on:
December 12, 2006, 07:25:08 PM »
I actually have a buddy that does audio installs, and he recommended 5.25s over those small component sets.
Logged
kenny kustom
Budget Lift
Reply #9 on:
December 12, 2006, 07:45:44 PM »
i am a mobile electronics installer, i had the component set in my 91, and i really liked them.
Logged
fony3
UberWheeler
Reply #10 on:
December 13, 2006, 12:32:38 PM »
I'll keep that in mind! although i think I am gonna get me an awesome deal on some JL 5.25s.....
Considering you are an audio installer, do you have a sub(s). If so i would really like to see some pics of what you did with your box.
Logged
dac
That CB Yapper
Reply #11 on:
December 14, 2006, 03:01:43 PM »
I put 4x6's up front, made my own brackets. They work well. As for a sub, I took the easy road and bought a 12" truck sub box from visions. It fits perfect behind the back seat.
Logged
This is not 'Nam, this is wheeling. There are rules.
triver525
Guest
Reply #12 on:
December 15, 2006, 07:21:15 AM »
I have a drawing of a bracket that I had made for my old TJ. It allows you to use 4" speakers in the stock locations. PM me or email me if you want a copy of it. I have it in DWG, jpg or visio formats.
Logged
fony3
UberWheeler
Reply #13 on:
December 15, 2006, 10:54:29 AM »
Thanks for the offer, but i am gonna probably buy for fab up some for 5.25"
Logged
triver525
Guest
Reply #14 on:
December 15, 2006, 10:59:57 AM »
Check you speaker specs. The opening required for the 5.25" speakers is probably much less than 5.25". The brackets I made had a hole that was 118mm (or 4.65") and the stock speaker cover went back on with no problems. In fact, my speakers may have been 5.25" after all. I do remember that a third of the speaker was hidden behind the dash. I also stuffed the hole area behind the speaker with wadding to allow the speaker to build up so pressure and to isolate front and rear of the driver.
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
