Author Topic: Top Truck 2007 Challenge  (Read 3955 times)
Jasona666
« on: February 01, 2007, 10:01:23 AM »
THROTTLE HAPPY
From Ontario
Quote
Okay here is the full specs. I am sure there is stuff missing but it is mostly there.
Engine - 454 Chevy big block bored .030 over, with TRW hypereutectic pistons, Arp rod bolts, Speed Pro hydraulic roller camshaft, Crane gold series roller rockers, Fluid Damper, Edlebrock intake, Holley multi port fuel injection (ordered, not installed yet), high volume aluminum water pump, Cloyes double roller timing chain, March pulleys, K&N air filter, Headman shorty headers through 3" exhaust with DNA race series mufflers, 100 HP Nitrous system, engine makes 625 Hp on the nitrous.
Ignition - MSD 6AL ignition box with 6000 rpm rev limiter, 8.8 MSD wires, MSD cap, MSD window switch, MSD 3 stage timing retard controller, CVR gear reduction starter, dual Exide dry cell batteries, emergency engine shut down and master electrical kill switches.
Fluid Cooling - Northern aluminum Radiator, Black Magic 2800 RPM fan, engine oil cooler, two external tranny coolers with separate fan, hydraulic steering cooler,
Transmission & Transfer Case - Built 350 Transmission, with Atlas II 4.3:1 Transfer case with 32 Spline outputs front and rear, and 1410 yokes.
Front Axle - Dana 60, 4.56 gears, Detroit Locker, Moser 35 spline outer axles, North West Fab Drive flanges, full hydraulic steering, rock ring diff protector,
Rear Axle - 14 Bolt, 4.56 gears, Detroit Locker, disc brakes, rock ring diff protector
Suspension - Front 3 link with 2.0" Fox coil over shocks with 14" of travel, links are 2.5" X 3/8" wall DOM with Evolution Machine heim joints,
Rear four link with 2.0" Fox coil over shocks and 14" Travel, lower links are 2.5" X 3/8" wall DOM, uppers are 2.25" X 1/4" wall DOM and running Evolution Machine heim joints.
Tires - 44" Boggers on 15" rims with B&M weld on bead locks front and rear.
Recovery - Warn 9000 pound winch in the front, Warn 6000 pound in the rear, full set of recovery tools.
Other Mods
Full roll cage, Removable snorkel, Willwood dual master cylinders and brake pedal, Onboard air with Viair compressor & tank, Rci fuel cell, Stainless Fuel lines and Russell fittings, Braided Stainless brake flex lines, 2 Holley electric fuel pumps, nitrous purge kit, full set of Autometer gauges, Grant removable steering wheel, Custom body, fire extinguishers, Custom cross member and skid plate, And a ton of spare parts.
Throttle Happy Offroad Forums
Throttle Happy TTC 07 ThreadThrottl3e Happy Vid
Jasona666
« Reply #1 on: February 01, 2007, 10:02:39 AM »
okay so at this moment there are two canadian competitors (hopefully both will make it to the votin mag........
TIMS FOR ALL OF US TO SUPPORT OUR CANADIANS ONCE AGAIN>>>
Okay so the two trucks are
TWISTER III "THE WARTHOG"
From Calgary
Evolution Forums
Jasona666
« Reply #2 on: February 18, 2007, 02:09:54 PM »
BOTH MADE IT INTO THE VOTING MAG NOW LETS GET THEM THERE WITH OUR VOTES............
« Reply #3 on: February 18, 2007, 04:00:25 PM »
Those are 2 deserving Canadian entries.  They have my vote :)
Giffer
« Reply #4 on: February 18, 2007, 05:41:39 PM »
wheres the vote?? and where do watch and see whats going on??
Jasona666
« Reply #5 on: February 18, 2007, 10:30:38 PM »
Four Wheeler....March Issue.....Vote
Jasona666
« Reply #6 on: February 19, 2007, 12:13:29 PM »
TTT
Jasona666
« Reply #7 on: February 21, 2007, 10:09:02 AM »
Mags Shoulkd Be Out Now....
Jasona666
« Reply #8 on: February 21, 2007, 10:39:16 AM »
As off of Pirate 4x4,,,,,,
:p
Jasona666
« Reply #9 on: February 21, 2007, 10:30:26 PM »
Jasona666
« Reply #10 on: February 21, 2007, 10:32:28 PM »
Jasona666
« Reply #11 on: February 26, 2007, 11:03:31 PM »
BUMP
Jasona666
Jasona666
« Reply #13 on: March 19, 2007, 08:55:46 AM »
Votin ends on the 31 must be in by then.....Go Team Canada
