Author Topic: Jeep TJ Model Changes By Year  (Read 1412 times)
sloria
« on: February 01, 2007, 04:00:15 PM »
Jeep Wrangler TJ
2005
New Exterior Colors:
Impact Orange
Deep Beryl Green Pearl
Discontinued Exterior Colors:
Solar Yellow
Shale Greeb
Sienna Pearl Coat
6-Speed NSG370 manual transmission replaces the 5-speed NV3550 & NV1500 transmissions in all models
6 forward 1 reverse
Max torque input 272 ft/lb
1- 5.014:1
2- 2.831:1
3- 1.789:1
4- 1.256:1
5- 1.000:1
6- 0.828:1
Reverse 4.569:1
Weight 40.5 kg
SE gets 3.73 axle gears in place of 4.11's/4.56's
Sahara Edition Discontinued
Second soft top on Unlimited, called "Easy-Folding Soft Top" now an option. (Dual tops still not an option on the Unlimited.)
New Premium H-Package on the Unlimited model features unique 2-tone cloth seats, silver painted center stack and instrument cluster bezels, bright grille and body color fender flares.
Optional six-disc in-dash CD changer system that arrives later in the model year.
2004
Solar Yellow
Lime Green
Inca Gold
Intense Blue
Trail Rated badges
The Canyon wheels in the 30" package are now "Ravine" wheels.
Can be purchased in the U.S. with right-hand steering
The standard AM/FM Tape is now a CD.
There is a standard spare tire cover that comes with the 30" wheel/tire package now.
There is a new "cubby bin" in the center "stack".
Willys Edition:
Exclusive Moss Green exterior color
Camo and black seats
Unique "WILLYS" decal at cowl side
Diamond-plate sill guards painted Dark Green
Body-color fender flares
AM/FM stereo radio with CD player and seven speakers (includes subwoofer in center console) - no extra charge
4.0L Power Tech I-6 engine
Tow hooks
Fog lamps
Full-size spare tire with matching wheel
Columbia Edition:
4.0L I-6 Engine
15-inch graphite painted aluminum wheels
Unique graphite fender flares
Fog lamps
Columbia badging
Dark Slate Interior
Khaki two-tone seats with the Columbia logo
Silver painted instrument panel accents
Available in Black, Bright Silver, Flame Red, Solar Yellow and Patriot Blue
Complimentary Columbia Bugaboo® parka featuring a zip-in Chehalis or Shoshone fleece vest
Rocky Mountain Edition: (Nearly Identical as Columbia Edition Except:)
4.0L I-6 Engine
30 Goodyear GS/A Tires on 15x8-Inch Alcoa Cast Aluminum wheels w/ full size spare
Fog lamps
Rocky Mountain Edition badging
Dark Slate Interior
Idential two-tone seats as Columbia Edition, but with Jeep embroidery replacing Columbia logo
Diamond sill plates
Tow hooks
Dana 44 rear
Introduction of Unlimited Model (2004 1/2):
10" longer wheelbase
5" extra rear overhang
Additional 13 inches behind the second row of seats (doubling rear cargo capacity to 29.5 cubic ft.)
Passengers in the rear seats pick up an additional two inches of leg room, and can now access the area with tip and slide seats.
3500 lbs. towing capacity (Extra 1500 lbs.)
New Sunrider soft-top, which lets drivers open a sunroof or take the entire top down
More sound insulation
Revised springs/shocks as well as an additional cross member out back to ensure an improved ride and no loss of structural rigidity
2003
Bright Silver Metallic
Light Khaki Metallic
Inca Gold Pearl Coat
Intense Blue Pearl Coat
Silverstone Metallic
Solar Yellow
Steel Blue Pearl Coat
Amber Fire Pearl Coat
Exterior Labeling:
On Sports, the word "Sport" now appears at the top of the fender where the word "Wrangler" used to appear.
On Saharas there's a brand new Sahara logo (much more discrete) that appears about where the "4.0L" used to
appear on early TJs, roughly where the "Sport" label appears on 2002s
Rubicon has RUBICON label on hood.
New Interior Colors:
Dark Slate replaces Agate
Khaki replaces Camel
Khaki color for Saharas instead of green trail cloth
Soft Top Colors:
Dark Khaki replaces Tan
Seat Changes:
Additional 20 millimeters of rearward travel
Taller seat backs
Softer seats
Seats are lower sitting (more like a car)
Lever on the side of the front passenger seat for easier access to the rear.
Rear seats are equipped with the LATCH (Lower Anchors and upper Tethers for CHildren)
New fold-and-tumble rear seat -- release now on the top center of the rear seat and a new spring mechanism helps it fold and tumble easier than ever before
New 3-ply Soft Top that is as quiet as the previous 4-ply
NOTE: Change in driver's side window: male zipper is now on window, female zipper on the top, previous years was vice-versa
Plastic windshield trim (Interior Upper Head Impact Protection to meet 2003 federal standard?)
Trim on back of hardtop and vents removed (vents added to tailgate)
New interior electrochromic rearview mirror with map lights, temperature and compass display
A new exterior mirror design reduces vibration, while increasing stability and durability. Shorter, fatter, and all plastic Now "ratchet" out from the body rather than swing out in a smooth motion.
Doors - the key cylinder is now chrome instead of black
Dashboard redesigned, openings for the radio and HVAC controls are now oval rather than rectangular
New 4-spoke vinyl steering wheel for SE and X models
New 4-spoke leather-wrapped steering wheel for Sport, Sahara and Rubicon models
Smoker’s Package optional on all models
On-Board Refueling Vapor Recovery (ORVR)
Additional power outlet on the dash
New flush-mounted AM/FM cassette radio with CD changer control
New flush-mounted AM/FM compact disc radio with CD changer control
Replacing the optional sound bar, new standard corner pods located just behind the b-pillar on both sides of the vehicle house interior lamps, providing theater lighting and optional speakers
Energy-absorbing foam is added to the sport bar
4-wheel disc brakes optional on Sport and Sahara
42RLE 4-speed automatic option
New transfer case skid to work with new 4-spd auto (lower ground clearance)
Jeep Wrangler SE Changes:
NV1500 five-speed heavy-duty transmission. Also used on Jeep Liberty, this transmission gives Wrangler a synchronized reverse gear and improved shift quality in cold weather. 4.56 gears available with SE and 4-speed auto.
Jeep Liberty’s 2.4-liter Power Tech I-4 replaces the 2.5-liter I-4 as the standard engine on 2003 Jeep Wrangler SE models. This 2.4-liter engine provides an estimated 150 horsepower at 5,200 rpm and 165 lb.-ft. of torque at 4,000 rpm, representing a 25-percent increase in horsepower and an 18-percent increase in torque. This increased power and torque is achieved through the use of aluminum cross-flow cylinder heads, dual overhead cams and a four-valve-per-cylinder design. The new 2.4-liter engine is quieter, more fuel-efficient and engineered for longer life and ease of maintenance.
Introduction of Rubicon Model:
Tru-lok selectable pneumatic lockers, activate in 4-lo and under 10mph, engaged until out of 4-lo or deselected
Limited slip in rear when not locked
NV241 Rock-Trac 4:1 transfer case -- fixed yoke
Heavy-duty driveshafts with 1330 universal joints
Dana 44 Front (Dana 30 outers)
4.10 gears
Goodyear Wrangler MT/R LT245/75R16 (31") Tires
16-inch, five-spoke aluminum wheels
Diamond plate rock rails
Rubicon Lettering on Hood
4-wheel Disc Brakes
Apex Edition:
Special hood emblem
Special seats
Freedom Edition:
Body colored fender flares
Special side badges
Outlined white letter P225/75R15 Goodyear all-terrain tires mount on 15-inch chrome wheels.
Standard soft-top with full metal doors, fog lamps and tow hooks.
Standard air conditioning, Sentry Key® theft-deterrent system, easy access Fold-and-Tumble(TM) rear seat and a choice of Dark Slate Gray vinyl or cloth seating.
Available in red, silver, blue and black exterior colors.
Tomb Raider Edition Rubicon:
16-inch Alcoa forged aluminum wheels
Tomb Raider badging with serial number
Light bar
Riveted fender flares in graphite
Black Tubular grille guard
Diamond plate bumper guard
Rock rails
Fog & Taillamp brush guards
Aluminum diamond plate bumper guard in black
Dark Slate fabric seats with red accent stitching down the center
Silver surround instrument panel bezel
Red seat belts
Available in Bright Silver.
2002
Shale Green Metallic
New Ecco Wheel and Tire Group with P225/75R15 OWL Tire replaces the Grizzly Wheel and Tire Group
New appearance for the Full Face Wheel
30" Tire and Wheel Group, speed control, full doors with roll-up windows and sentry key are now standard on the Wrangler Sahara
Full doors with roll-up windows, fog lamps and tow hooks are now standard on the Wrangler Sport
Fog lamps and tow hooks become separate options
New HVAC System with overall improvements in performance and quietness
New Fuel Tank Skid Plate with Added Reinforcement
Premium sound system that includes 2 new tweeters in addition to the existing subwoofer
7 year/70,000 Mile Warranty Offered (Not on early 2002's however)
Introduction of X Model:
4.0L engine and cloth seats, standard, less options than Sport (no Dana 44)
2001
Sienna Pearl Coat
Medium Fern Green
Desert Sand
New 4-ply Soft Top that is more durable and quieter
Quarter-Turn Fuel Filler Cap
New Anti-Lock Brake System
Long Life 100,000-Mile Engine Coolant that is more Environmentally-friendly
Quick-Removal Side Steps
All-New steering wheel tilt mechanism provides reduced effort and an increased range of adjustment
Optional molded plastic Add-a-Trunk for reduced weight
Optional Amplified Sub-woofer
Re-designed Stereos
Mini Console with dual cup holders
Re-designed Full Console with rear seat cup holders
Sutton Vinyl Seat Material - Standard on SE and Sport Nomad Cloth Seat Material - Optional on SE and Sport
New wider inside rear-view mirror
New Multi-function Steering Column switch combines headlamp, fog lamp, turn signal and windshield wiper functions
Intermittent windshield wipers made standard
New Instrument cluster includes a fog lamp tell-tale light and provides Parade-Mode lighting, battery saver control of interior lighting and odometer display with door open
User-Ready Child Seat Anchorage System
The pull switch for the headlights moved from the dash to the blinker
Late Model:
60th Anniversary Edition
Available only in Black or Silverstone Metallic
Body-color wheel flares and rocker sills
Specially embroidered floor mats
Full Metal Doors
Canyon 30-inch Tire and Wheel Group
Fog Lamp and Tow Hook Group
Air Conditioning
AM/FM stereo readio with CD player, five speakers and subwoofer
Options: Speed control & Dual-Top
2000
Solar Yellow
Patriot Blue Pearlcoat
Silver Stone
Chilli Pepper Red,
Gunmetal Blue
Intense Blue
Deep Amethyst.
Alternator moved higher up
Ultra Star 16" alloy wheel now standard on Sahara models.
4.0L engine now gets distributorless direct-ignition system, re-designed cylinder head, new exhaust manifold and dual-catalyst system (2.25" exhaust)
New NVG-3550 manual transmission replaces the Aisin transmission on the models with the 4.0L engine (includes synchromesh on reverse gear).
Sound Bar now standard on Sport models.
Tow hook option now includes one rear tow hook.
Sport's standard AM/FM radio adds a cassette player, Sahara exchanges a cassette player for CD player.
Optional tilt steering wheel in SE and Sport is now the same leather-covered unit that was standard in Sahara.
Child-seat tethers added to the rear seat,
1999
Medium Fern Green Pearlcoat
Forest Green Pearlcoat
Desert Sand Pearlcoat
Intense Blue Pearlcoat
Jade
Lapis Blue
Emerald
Moss Green
Gunmetal Pearlcoat
Agate
Camel
New Top Colors:
Dark Tan replaces Spice.
Hood cowl changed from a "3 section" wide cowl with alot of plastic around it to a smaller cowl...
Removed annoying useless vent that leaks water
Cruise control controls on steering wheel
Rotary climate controls with bi-level air
Defeat switch for passenger-side air bag
Improved ECM
Re-designed catalytic converter
New "JTEC+" engine controller with new engine-function sensors
Lighter frame - 16 lbs (8kg) lighter
Nineteen gallon fuel tank now standard.
30" tire package came with the "Canyon" style wheels (15x8).
1998
Chrylser becomes Daimler/Chrylser
Chili Pepper Red Pearlcoat
Deep Amethyst Pearlcoat
Smart Key Immobilizer replaces previous Lock/Unlock keyfob system.
Cruise control Available
Ez-Entry Driver's seat now available
Revised torsion bar for improved steering response
Revised steering gear ratio that varies from 15:1 on centre to 13:1 at the extremes of travel for more responsive steering
New steering wheel
Next generation airbags
Revised stereo range
Hood latch changes
3.73 ratio rears and Dana 44 Rear
New engine managment system wiring
Dual Tops Option
Added pads to front bumper -- front license plate moved to the center of the bumper
30" tire package came with the "Gambler" style wheels (15x8).
Late Model:
1997
Introduction of TJ Model:
All-new, refined exterior body panels and hardware
Quadra-Coil Suspension
Contemporary interior appearance and dash
New frame with outstanding torsional and bending stiffness
Driver and passenger air bags
Optional ABS
Improved soft top (quieter and easier to put up/down)
Round headlights return
Lockable glovebox
Available exterior colors:
Black
Bright Jade Satin Glow
Citron Pearlcoat
Dark Blue Pearlcoat
Emerald Green Pearlcoat
Flame Red
Gunmetal Pearlcoat
Lapis Blue
Moss Green Pearlcoat
Stone White
AX-15 5-spd Transmission
Annoying useless extra vent behind the hood that leaks water
No screen to in cowl vent
Cambolts for the front control arms
Knock-outs for the rear control arm cam bolts
Ability to display the diagnostic codes on odometer with key on,off,on,off,on
You have to switch a plug to disable the clutch/starter interlock
AX15 for the Manual Tranny or a Chrysler 999 for the auto if it is a 6 cylinder
AX5 for the Manual Tranny or a Chrysler 904 for the auto if it is a 4 cylinder
Optional dana 44 with 3.55's gears
Front License plate on the passenger side of the bumper.
Late Models:
3.73 ratio rears and Dana 44 Rear ?
Hood latch changes
1996
NO WRANGLERS PRODUCED FOR THIS MODEL YEAR
Jeep Wrangler YJ
1995
Last year of YJ Production
1994
Three-speed automatic transmission available with 2.5-liter engine
1993
Four-wheel anti-lock brakes available
1991
4.0-liter Power Tech, OHV, 12-valve, SMPI I-6 Power-Tech Six engine replaces 4.2-liter engine
1988
Sahara model introduced
1987
Initial YJ introduction, square headlights, leaf springs
Offline apex
« Reply #1 on: February 01, 2007, 04:14:44 PM »
Good stuff!
+1 Karma for you!
Offline NS-jeeper
« Reply #2 on: February 01, 2007, 11:07:41 PM »
This should be a sticky
