Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
Head All replaced
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Head All replaced (Read 688 times)
Jeepgirl
Guest
Head All replaced
on:
May 27, 2008, 08:21:07 PM »
Will a head from a 94xj 40 work on a 92 yj 4.0 HO??? Can someone please let me know Thanks Very Much
Last Edit: June 16, 2008, 01:28:18 AM by Jeepgirl
Logged
Mr-B
Guest
Re: Head
Reply #1 on:
May 27, 2008, 08:40:28 PM »
yuppers it should, check the head casting number, probably be 0630, the number will be on the top of the head, next to the valve cover, should be visible without taking stuff apart...
Last Edit: May 27, 2008, 08:42:16 PM by Mr-B
Logged
yjcanibul
Guest
Re: Head
Reply #2 on:
May 27, 2008, 10:52:32 PM »
91-95 4L should be casting #7120 (HO) which covers both your jeep and donar so as Mr.B said check midway along drivers side where valve cover meets block ... its clearly visible in good light , the following article suggests there are benefits/less issues sticking with your current head design ... if it is a #7120 you'll want to stick with it ...
http://www.jeepsunlimited.com/forums/showthread.php?t=839075
I believe 96 upto 98 4L used #0630 and then changed up again for 99 onward ...
Logged
Jeepgirl
Guest
Re: Head
Reply #3 on:
May 28, 2008, 12:01:53 AM »
Thank you for the help this is new to me.
Cheers
Logged
Mr-B
Guest
Re: Head
Reply #4 on:
May 28, 2008, 08:49:41 PM »
I think your right on the years yjcanibul...my mistake, way too much on the brain with the stroaker project
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
Head All replaced
