Author Topic: CB Antenna mounts.  (Read 2422 times)
Offline redbull
CB Antenna mounts.
« on: September 26, 2005, 01:13:22 AM »
I'm looking at the Tera Flex one that bolts up behind the tail light. They sell both sides, I'm thinking driver's side. Any thoughts?
CB Antenna mounts.
« Reply #1 on: September 26, 2005, 09:41:36 AM »
Peice of angle iron with a hole drilled and bolted to the top of the tire carrier is a cheap an simple solution.
If you were looking for other suggestions. If not, nevermind.
Da_chopper
CB Antenna mounts.
« Reply #2 on: September 26, 2005, 10:31:20 AM »
Quote from: "bnine"
*2 and you don't have to drill in your tub.
Offline redbull
CB Antenna mounts.
« Reply #3 on: September 26, 2005, 11:10:42 AM »
Quote from: "bnine"
I thought of this, but was wondering about cable routing. A tub mount (and the TeraFlex one shouldn't need any new holes drilled) would have a static cable, but the mount on the tailgate would have a longer run that would need to flex when the gate is opened, right?
CB Antenna mounts.
« Reply #4 on: September 26, 2005, 12:59:18 PM »
Mine is routed out of the same hole where the 3rd brake light used to exit.
Once its in the carpet right by the door, it doesnt move much, or get hung up on stuff.
My cb is on my rollbar, so interior routing was the same distance down either side.
Offline redbull
CB Antenna mounts.
« Reply #5 on: September 26, 2005, 04:45:25 PM »
Quote from: "bnine"
1991 YJ here, no 3rd brake light. You have given me some ideas though.
CB Antenna mounts.
« Reply #6 on: September 26, 2005, 09:03:28 PM »
Yeah, holes already there  on the tj's. Not tough to drill an grommit one though if you really wnat it there.
good luck
Da_chopper
CB Antenna mounts.
« Reply #7 on: September 27, 2005, 06:59:06 PM »
Quote from: "redbull(and the TeraFlex one shouldn't need any new holes drilled[/quote
You have to drill one hole with the Tera-flex one, else it's kinda wobly.
