Author Topic: Land Use Framework - Feed back survey  (Read 2115 times)
Lurch
« on: June 18, 2008, 08:10:03 AM »
I received this from a friend - It give you a chance to comment on what you thought of the LUF survey
It is one last chance to get  your points heard!
The Proposed Land-use Framework Needs Your Voice
WHO? Every Albertan
WHAT? Take some time to fill out the Draft Land-use Framework Public
Feedback Survey
WHEN? NOW!! Deadline for input is JUNE 20
WHERE? Online website ( <http://www.banister.ab.ca/landfpfs/>
http://www.banister.ab.ca/landfpfs/)
WHY? Land-use is a key component of sustainable development. A well thought
out plan is in the best interest of all stakeholders.
What is the Draft Land-use Framework?
After a year of effort on behalf of four multi-stakeholder working groups,
the Government of Alberta used their input to develop a Draft Land Use
Framework. On May 21, the Government of Alberta released the proposed Draft
Land Use Framework ( <http://www.landuse.alberta.ca/>
http://www.landuse.alberta.ca/). This important new provincial policy will
profoundly effect how land and water are used in the future. It outlines a
new system for land-use in the province.
Why is your input important?
Public response to this document will be seen as an indicator of whether or
not Albertans are supportive of the Land-use Framework...whether Albertans
are supportive of change and action.
Without public backing for the Land-use Framework the result could be - a
'business as usual' scenario. For the Land-use Framework to be implemented,
the government must receive a clear message from the public that they
support this policy initiative.
Your feedback is critical for ensuring the final Land-use Framework reflects
the views of a broad cross-section of Albertans.
