Author Topic: building a jeep do you think this will fit  (Read 2619 times)
Offline LEMON-AID JAY
  • Bad a$$ zj owner
« on: July 11, 2008, 10:22:04 AM »
 :o
E-mortal customs
Www.e-mortalcustoms.com
3-2808 Ogden road s.e.
E-mail. [email protected]
Phone 403-265-6669
E-mail @ [email protected]
for all your 4x4 needs
www.piratesof4x4.com
Re: building a jeep do you think this will fit
« Reply #1 on: July 11, 2008, 03:36:16 PM »
Better get a bigger hammer...
« Reply #2 on: July 11, 2008, 06:30:37 PM »
id ditch the flares and call it done... that jeep better have a 4.0L too;)
Offline barmanjay
« Reply #3 on: July 11, 2008, 07:09:23 PM »
DOOOOO-ITTTTT!!! :D ;D :D ;D
The realtor that gets dirty
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
Offline RACKMAN
« Reply #4 on: July 12, 2008, 09:43:00 AM »
Are you going to run it with the air brakes operational? 8)
RACKMAN
  • Bad a$$ zj owner
« Reply #5 on: July 13, 2008, 09:50:48 AM »
no air brakes for me I will make a set of pinion brakes.
OK here is the plan I will be takeing a94 YJ makeing it a 4 door with the help of another tub. then installing the 8ton diffs and t-case. put in some sort of big block and 2wd tranny. It will be running 2 sets of tires 53" for play and comps 66" tires for monster truck shows.  :mrgreen:
here is some more pic's
I have rockwell parts going into the new rig here is the rockwell 2speed T-case with front axle disingage
sitting high
locker switch for the rear diff
this is a brake drum
E-mortal customs
Phone 403-265-6669
  • Bad a$$ zj owner
« Reply #6 on: October 06, 2008, 09:30:03 PM »
update ???
E-mortal customs
Phone 403-265-6669
Offline Waytec
  • not all there
« Reply #7 on: October 06, 2008, 09:42:57 PM »
With a big enough hammer and a welder you can build anything.
The obstacle is the path.
  • Bad a$$ zj owner
« Reply #8 on: October 13, 2008, 08:20:49 PM »
well change of plans jeep is not the new look but if its ok I will still post updates.....
well the Lemon history started with an 83 dodge ramcharger then went to a very cool 53 dodge pick up now we will bring to life the 3rd gen of the lemon line (the new school lemon). Bye bye jeep hello my friend dodge.
ramcharger lemon
53 old school lemon
« Last Edit: October 14, 2008, 07:56:48 AM by Joel »
E-mortal customs
Phone 403-265-6669
Offline Elsifer
« Reply #9 on: October 14, 2008, 10:23:22 AM »
Remember that the pinion spins X times faster than the tires due to the gearset in the diff. Those rotors will get very, very hot.
You'll have to find a way to let the heat out of the rotor, rather than let it seep up and down the driveline. I've seen countless seals go on pinions and ujoint caps.
Cross drilled and slotted rotors might be the way to go.
Might be worthwhile to try and convert to hydraulic disc brakes, and save the pinion brake for an e-brake/parking brake. Look at Willwood for the calipers and rotors and bracketry to go on the Diff. Then there is also USA6x6 (if you are willing to wait for a long delivery time).
Or keep the air-brake setup? Not sure if you would need a Class1 or air-brake endorsement for an OHV application.
Good luck with that, let us know how it turns out!
« Last Edit: October 14, 2008, 10:25:15 AM by Elsifer »
VA6CPL
Jeepless....
« Reply #10 on: October 14, 2008, 06:16:31 PM »
Disc Conversion ? :)
