4x4 Related Groups => Tech Talk => Topic started by: sylvrinvader on November 17, 2008, 09:24:11 PM
Title: hard top question
Post by: sylvrinvader on November 17, 2008, 09:24:11 PM
will one from a 97 tj fit my 03 tj
Title: Re: hard top question
Post by: fug on November 17, 2008, 09:57:16 PM
Yes.  The big difference is the venting.  The 97 will have a vent down the side of the hardtop... your 03 will have vents built into the tailgate.  So putting the 97 top on the 03 jeep means you have double the venting.
Post by: sylvrinvader on November 17, 2008, 10:33:02 PM
more ventings a good thing i take it. less window fogging up in the rear
Post by: fug on November 17, 2008, 10:37:27 PM
Yeah I don't think having the vents in both places would be a bad thing at all.  If you try to put a later hard top on an older TJ I think it can make it a bit harder to close doors etc cause they get pretty air tight with out the vents
Post by: Yellow RUBI on November 19, 2008, 10:16:10 AM
Are You getting another top?!!
Post by: RckyMtnTJ on November 19, 2008, 03:17:17 PM
I've heard the clamps at the windshield are different too, due too the plastic trim on the 03' and newer.  Nothing important though.
Post by: Archi-Jp on December 22, 2008, 12:28:17 AM
Anyone have experience wiring up the hardtop?
I just bought a hardtop & would like to get this in place...
Oh yeah, '99 TJ Sport...
Post by: fug on December 22, 2008, 07:20:03 AM
Wiring? What wiring?
The only thing I can think of that would require any wiring would be the rear defrost and wiper if it has one.  On mine that's just a 2 wire plug and should be pretty easy to do.  Take a look around the drivers side rear of your tub and see if there's a plug already there.
Post by: calltrex on December 22, 2008, 10:43:19 AM
I just put a 97 top on my 2003
just take the conector out of your original and put it in the new onw. mine poped right in.
only other thing i had to do was drill 2 holes in the back.  The 2 holes for the bolts to hold the top down were about 2" different from my origional top.
