4x4 Related Groups => Tech Talk => Topic started by: shlly on November 29, 2008, 05:07:59 PM
Title: 95 yj
Post by: shlly on November 29, 2008, 05:07:59 PM
Help please!    I just bought this jeep and dont know a lot about it but I do know my dashlights and horn Dont work???????????? Found fuse box but havent any idea which one to check
Title: Re: 95 yj
Post by: Gearhead on November 29, 2008, 05:15:22 PM
Horn fuse is in the power distribution box , beside the battery.
Rote the dial beside your headlight switch to see if the dash lights come on , this is a brigthness control. If that doesn't work , check fuses or you may need a new headlight switch , they are not known to last forever.
Title: Re: 95 yj
Post by: sylvrinvader on November 29, 2008, 05:50:20 PM
where r u located maybe i can have a look at it
Title: Re: 95 yj
Post by: yjcanibul on November 29, 2008, 06:52:21 PM
horns are also easy come easy go
take it off and run a little wire from battery to pos side and ground it cause it is most likely dead - if it needs replacing mount it facing backward toward firewall it will last longer ...
used horns are if'y ... I once tested one out of junk yard and it blew ... once ... wasted 10$,  cdn tire has a look alike for about $25 ...
