4x4 Related Groups => Tech Talk => Topic started by: cdnhonda on December 21, 2008, 10:05:53 PM
Title: t-case swap
Post by: cdnhonda on December 21, 2008, 10:05:53 PM
i have an 89 jx with a np242 t-case that i blew up and want to swap in a np231 what do i all need to change ie drive shafts 4x4 lever
thanks
Title: Re: t-case swap
Post by: cdnhonda on January 05, 2009, 04:25:38 AM
bump
anybody?
Post by: morerpmfred on January 05, 2009, 05:16:42 PM
use same drive shafts, Adjust linkage on unibody. possible change shifter arm on t case or reindex arm depending on what vechcle it came out of. Have to use pre 96 t case to get the long 2 piece  tailshaft assembly. And spline count and shaft lengh have to be the same, 23 spline and I forget the shaft length . Just did the reverse swap, blew up a 231 went to a 242 as i got a really good deal.And that was an xj ans not a susuki jx? Now would be a good time for a sye if you are going to lift it.
Post by: LifesGrand on January 06, 2009, 06:21:44 PM
I have a nice write up for a zj, but I'm sure the rules still apply?
Might help for reference???
http://jeephorizons.com/tech/tcase.html
