4x4 Related Groups => Tech Talk => Topic started by: 86 irocz on April 19, 2009, 10:48:18 PM
Title: 1994 jeep grand cherokee (where can you mount hooks for pull points?)
Post by: 86 irocz on April 19, 2009, 10:48:18 PM
not shure where would be a good place to mount these  got 10000 pound hooks want to mount them on the fromt of my grand cherokee but theres not really anywhere to put them any help  would be great thanks
Title: Re: 1994 jeep grand cherokee (where can you mount hooks for pull points?)
Post by: WhiteOut on April 19, 2009, 10:50:12 PM
You need mounting plates that bolt onto the frame rails.  Do not mount them without brackets, you'll have them ripped out and go flying.
Post by: JackstandJohnny on April 20, 2009, 02:53:00 PM
any offroad store should sell the brackets you need. i think modern has them in stock. i got some (complete with hooks) from the auto wrecker a few years ago.....
just an FYI you cannot mount tow hooks to a ZJ cheap..... if you just drill two holes and bolt in teh tow hook it WILL rip out. the factory stock tow points are a bracket in a kind of 'L" with a big bolt plate that bolts into teh side of the 'framerail' and is sandwiched by another bolt plate on teh other side, and there is an extension which bolts into the radiator support
Post by: 86 irocz on April 22, 2009, 02:42:52 AM
awesome thanks guys
will go check out those brackets then
thanks for the help
Post by: 2grand4u on April 22, 2009, 07:33:38 AM
awesome thanks guys
thanks for the help
they go on you rad support so go to pnp and grab one that you can use for hooks or get and aftermarket one that pushes the rad up
