General Forums => Chit-Chat => Topic started by: jandh on April 27, 2009, 10:33:00 PM
If you don't know the lift above stock on your jeep, how can you measure it?
say if I measure from the center of the rim to the fender would that tell me?
or from ground to fender... utilizing same tires, of course.
what would be the stock measurement from the center of the rim to the fender?
anyone with a stock XJ still?
i think XJs are all different ...mine has 6" lift and JUST sits higher then my friends with only 3" lift and my tires are 2" bigger
really - thats interesting.
from the top of my tire (235 75 15's) to the fender was 2 inch's after the Grand Cherokee coils were added it went up to 4 inch's
so in theory a 2 in lift - is 4 inch's enough clearance for trial rides?
If you're running stock rims, the tires should tuck up into the fender if they travel far enough. 4" should be good to get you on the trails and wanting more lift, bigger tires and lots more toys that you see out there.
I'll check my stocker in a bit for ya.
awsome thanx
From top of tire to bottom of fender... 4"
From ground to bottom of fender... 31.25"
225/70/15 tire
So you basically got 1" over the stock height or 2 " over the sagged out height you were at.
1" over stock is fine for upto a 30" tire, past that either trim fenders or more lift.
