4x4 Related Groups => Tech Talk => Topic started by: specialk on May 01, 2009, 06:11:31 PM
I had a lift put on my 04 TJ Rubicon about a month ago. I've noticed a burning smell (smelt electrical) 3 or 4 times while driving; usually after about 30 mins.; a couple of times I noticed a whiff of smoke but thought it was exhaust on cool days. Today I found the source of the smell and smoke - from the drivers side rear wheel.
I've popped off both rear wheels and the driver side is definitely tight to turn around. Pasenger side turns free.
No leaks in the rear end. Brake fluid is good. Rear diff fluid is good. Both brake pads appear to be the same. No noticable large grooves on the brake discs.
The metal surface on the hub in front of the disc brake looks flakey. If I took a wire brush to it, it would come off. Does anyone have any thoughts?
Calipers seizing? Some thing worse in the axle?
Kev
maybe the e-brake is hangin up. check that first.
check the beerings?
Probably the e-brake cable stretched slightly and partially engaging the brakes or the cylinder on that side is partially seized.
Ended up being a seized caliper. Damaged the rotor and pads on that side too so I'm replacing the rear brakes on both sides.
Thanks for the info guys!
