4x4 Related Groups => General Talk => Topic started by: KrossLoch Fab on May 27, 2009, 12:05:24 PM
Please see the link on EJC.
(I need tutoring on posting pics on this site!!!)
http://edmontonjeep.com/forum/viewtopic.php?f=28&t=7371
Should be the same to post pics on EJC, host your photos on a site like photobucket.com,then copy the link here and press the little IMG tag in the reply screen...insert the copied link inbetween the IMG tags.
Make sure people use the outer bumper tabs as well. On my old XJ I pulled the heads of the bolts THRU the unibody!
Good advice my friend!
Here you go Craig...
(http://edmontonjeep.com/forum/download/file.php?id=4757&t=1)
(http://edmontonjeep.com/forum/download/file.php?id=4756&t=1)
(http://edmontonjeep.com/forum/download/file.php?id=4758&t=1)
(http://edmontonjeep.com/forum/download/file.php?id=4759&t=1)
It would be also good if you would find a way to sleeve the holes that the 3 steering bolts goes through from side to side of the unibody... and weld the sleeve on both reinforcement plates.... there is a 4/3" to 1" hole that goes through the unibody a bit closer to the shock. You could put a rod through that also and weld it on both reinforcement plates also. Roseweld the crap out of both plates and box it in with a little plate on the underside on the unibody...
I have the JKS version of of that... that's what they do and it's it solid as a bastard.
(http://store.jksmfg.com/merchant2/graphics/jks/p_ogs960.jpg)
This is a great mod for an XJ... the unibody is prone to crack where the steering ... Nice Job!! ;D
Awesome! That is an cool mod too! Thx Swampsinger!
