4x4 Related Groups => Tech Talk => Topic started by: Grease Nipple on June 01, 2009, 10:13:44 PM
Does anyone know of a place I can take some carbs to for a ultrasonic clean/chem bath?
I have 4 in total, off of a motorbike.
TIA!
Or better yet some chemdip with a dipping bucket or something simular.
i have tried
canadian Tire
AutoValue
Partsourse
something like this
http://www.berrymanproducts.com/Default.aspx?tabid=146
(not sure if I can post live links)
Hey ibyers
Being the current owner of some 10+ CB750 4's, I seem to have a ton of experience cleaning carbs.
Easy solution, and you get to eat stuff!!
First, go buy two 4 litre pails of the cheap ice cream, flavour of your choice!
Second, eat said ice cream!
Third, drill small holes in the bottom of one of the pails. The more holes, the faster it drains. Ensure holes are smaller than the parts you are cleaning. I use 1/16" drill bit.
Fourth, go to CT, Parts Source, NAPA or any place else and buy a container of GUNK Hydro Seal II, and at least one can of carb cleaner per carb, some rubber gloves (not the latex gloves, but good rubber gloves).
You now have a dipping container and the best carb cleaner out there. The two ice cream containers stack together perfectly!
Remember, WEAR the gloves, trust me. Wear eye protection too. The stuff is toxic and will eat through rubber FAST, but cleans better than anything. Also, it can be neutralized with water!
Remove ALL rubber gaskets, dissassemble the carbs (one at a time), let sit in the solution for a while, then shoot all passages with the canned carb cleaner, reassemble and you should be good to go. You'll have to make sure all your needles are set properly and that the carbs are balanced after too.
Save the GUNK stuff because it is still good. Can clean about a hundred carbs! Just don't get water in it. Run it through some cheese cloth when you put it back in the can.
Good luck and enjoy the ice cream!
i like icecream.............
I'll help you empty those ice cream bukets! ;)
Stopped by Autovalue and picked up a jug of Hydro seal II, going to Sobeys tonight to buy a few tubs of ice cream, Johnny we have some eating to do!
(i can't belive I don't have any ice cream buckets kicking around, anyone have any)
I am sure you could find a couple in some of your neghbours new blue bins ;D
How goes the ice cream eating? Did you get some apple pie to go with it?
