4x4 Related Groups => Tech Talk => Topic started by: gsxtacy on November 21, 2005, 03:26:34 PM
Title: 2.5 L to a t-90/t-18
Post by: gsxtacy on November 21, 2005, 03:26:34 PM
hey folks, i'm sure most of you have heard of my new rig (soonly) it's a 47 cj2a, and i'm dropping a 2.5l i4 from an 85 cj7 in between the rails.  just wondering which tranny would work better? (and with out much modding)
can anyone tell me what xcase this jeep came with, so i can figure out whether or not i'll need adapters?
thanx!
Title: trans
Post by: henry on November 21, 2005, 04:52:18 PM
I have an AX5 for sale, and a TJ or YJ bellhousing as well.
Darren
Post by: gsxtacy on November 21, 2005, 05:13:39 PM
hold on, what did you just say?
i told all, i'm new at this and you shouldn't be using the acronyms on me.
thanx!
Post by: MTSman on November 26, 2005, 06:18:43 PM
The Jeep CJ 2.5l engine is actually a GM engine, using the Small block Chev bolt pattern. Use any GM transmission you like and buy the adapter to adapt it to your Tcase......OR......Use a GM engine ,trans and tcase and just swap out your rear diff for one that is centered.
Personally I'd stay away from the T90, I've rebuilt lots of them and they're marginal at best, use something made AFTER you were born, it'll be easier to keep on the road.
Check your PM's, a friend of mine has a flatfender project that needs assembly that sounds like just what you're planning on building.
Post by: gsxtacy on November 26, 2005, 06:27:56 PM
gotcha
thanx!
