4x4 Related Groups => Tech Talk => Topic started by: BUKI on June 23, 2009, 05:57:21 PM
Title: sye questions.
Post by: BUKI on June 23, 2009, 05:57:21 PM
been along time since last post.  So HI
Ok, I originally lifted my jeep with a 4" RE kit.  It came with everything.  I installed the T-case lowering kit and the shims for the axle.  But now I have a SYE in the T case and proper driveshaft  from DSI.  I have been driving it for well over a year now, and never thought any different.  As of 10 minutes ago I was wondering if I was supposed to pull the lowering kit and the axle shims????
thanks
Mike
Title: Re: sye questions.
Post by: slimbeam on June 23, 2009, 06:47:44 PM
when I did my lift I had the T case lowered, but when I put in the SYE I took the spacers out so it was back like stock, I would leave the shims in though so the pinion is pointing at the T case
Post by: Fredduck on June 23, 2009, 07:32:11 PM
If the u-joint angles are good, the t-case drop doesn't bother you and it doesn't vibrate I'd leave it.
Post by: BlackYJ on June 23, 2009, 10:16:30 PM
With the length gained from the SYE you can remove the t-case drop but the shims are a must.  Ideally the pinion should be pointing at the t-case yoke, but if you are a little lower that is not a problem.  My pinion does not setup perfectly but works fine
Post by: BUKI on June 24, 2009, 05:18:10 PM
cool thanx for the info
