4x4 Related Groups => Tech Talk => Topic started by: jeepers26 on July 03, 2009, 08:06:11 AM
Title: 02 WJ CV boot ripped
Post by: jeepers26 on July 03, 2009, 08:06:11 AM
My 02 Grand has a rip in the cv boot.. I caught it right away I had to drive it about 100 km's home.. now the question is should I just replace the boot or change out the whole shaft?.. I read somewhere that if the boot is ripped the joint is already toast, is this true? any help would be appreciated.. thanks
Title: Re: 02 WJ CV boot ripped
Post by: jeepers26 on July 03, 2009, 08:35:16 AM
does anyone think I should just change the boot for now and get some more wear out of it, then change the shaft when it absolutely needs it?
Post by: JackstandJohnny on July 03, 2009, 09:06:55 AM
if you do that might as well carry a spare for when it blows out on you on the trail...........  and if you gonna get a new shaft might as well just swap it in right away...........
have you looked at converting to regular U-joint axles?
Post by: jeepers26 on July 05, 2009, 12:55:47 PM
I would think that, that would be a better way to go... more servicable..would anyone know where to get a set of u-joint front axle shafts for my 02 WJ with quadra-drive? cause  I don't want to have to replace another CV boot.. what a dirty #$%#ing job.
Post by: Mikes off road on July 05, 2009, 01:05:10 PM
I have some dana 30 front shafts that I was using as spares. The only problem is that I have accumulated two to three spare shafts for both the passenger and driver side. Willing to let them go for $40 apiece if they fit your application.
