4x4 Related Groups => Tech Talk => Topic started by: YoungFluff03TJ on August 25, 2009, 05:24:35 PM
Title: 4 lo is a no go
Post by: YoungFluff03TJ on August 25, 2009, 05:24:35 PM
So i put on my 3" lift for my TJ with a T-case Drop, all is fine. I had clearance issues with my shifter going into the lower gear (2,4,R) so i took the boot off and its perfect. But...4 low wont go into 4 lo. 2, 4 Hi Neutral are all fine....do I just need to shave the plastic back a bit same as the shifter? or is something more drastic neccesary?
Title: Re: 4 lo is a no go
Post by: JackstandJohnny on August 25, 2009, 08:59:05 PM
i think you solved your own problem.............
Post by: Bnine on August 26, 2009, 09:46:01 AM
No, you just need to adjust the rod to correct the placement of the shifter throw.
Post by: YoungFluff03TJ on August 26, 2009, 11:27:15 AM
i just like to consult experts before i hack  the inside of my child
Post by: LifesGrand on August 26, 2009, 03:57:24 PM
I think what Bnine is explaining to you is do not cut any plastic, crawl underneath the jeep, find the linkage adjust screw & muck wit it.
