4x4 Related Groups => Tech Talk => Topic started by: WagoneerXJ on December 13, 2009, 02:27:22 PM
Title: Which oil in a 1993 XJ AX-15 transmission?
Post by: WagoneerXJ on December 13, 2009, 02:27:22 PM
Want to change the oil in the XJ's tranny, what do I put in there? some people say ATF, some say gear oil....I obviously don't want to use the wrong one, and haven't found an answer yet. What say you?
Title: Re: Which oil in a 1993 XJ AX-15 transmission?
Post by: BlackYJ on December 13, 2009, 04:37:03 PM
The manual says 75w-90 GL5 and I have always used GL5.  In the newer XJ-15s it does say use a GL4
In my '95 XJ-15 and am running currently Redline MT-90 I believe which is the low sulfer gear oil, but I will be switching back to Redline 75w-90 GL5 because it ran better.  I would highly recommend running a good sythetic 75w-90 gear oil.  It made mine run smoother and quieter
Post by: Justink on December 13, 2009, 04:57:45 PM
I run ATF and it works fine.
Post by: WagoneerXJ on December 13, 2009, 07:31:01 PM
well if the manual says 75W90 gear oil, that's what it will get. Probly Royal Purple :)
