4x4 Related Groups => Tech Talk => Topic started by: Justink on December 21, 2009, 07:24:59 PM
Title: driveshaft angle
Post by: Justink on December 21, 2009, 07:24:59 PM
so i know back driveshaft angle has been gone over alot but whats a decent front driveshaft angle or do i have to worry?  i blew 2 cups out on the cv joint and was wondering if driveshaft angle had anything to do with it, or if  i just put it in bad.   :-[  I am currently runnin a 4.5 inch lift if that matters
Title: Re: driveshaft angle
Post by: dac on December 21, 2009, 07:34:05 PM
Don't quote me on this but I think your caster is more important than drive shaft angle.
Post by: Justink on December 21, 2009, 08:04:47 PM
caster is the angle of the diff, or what is it?
Post by: dac on December 21, 2009, 08:26:52 PM
more or less.  Think shopping cart front wheels.  Diff angle kind of falls out of it.
http://en.wikipedia.org/wiki/Caster_angle
Post by: Justink on December 21, 2009, 08:38:45 PM
so i know on the back you can get sloped blocks to improve the angle, but what about the front being as its coils?
Post by: dac on December 21, 2009, 08:48:23 PM
You stumped me on that one.  You may or may not have cams on the lower control arms?  You can also get adjustable arms.
Post by: Justink on December 21, 2009, 08:52:01 PM
i just thought of the control arms  :-[
I am running procomp control arms. which brought the diff down.  So by buying longer uppers i should be able to cancel out the effect of a longer lca?  or do I have to go out and buy adjustable control arms?
Post by: dac on December 21, 2009, 08:57:15 PM
So you just put the lowers on?  I wouldn't get solid uppers, go adjustable and save the headache.  As for dialing it in, I can't remember what the angles should be.
Post by: esi on December 21, 2009, 09:08:56 PM
doesn't your diff have cam bolts at the diff end of the LCA's. If not a set of them might solve your problems.
Post by: Mudhawg on December 21, 2009, 09:25:44 PM
both cherokee's ive had 1990/1996 dont have cam bolts on the LCA's
Post by: Justink on December 21, 2009, 11:12:40 PM
pretty sure mine aren't cam bolts.  whats the difference?
Post by: esi on December 21, 2009, 11:13:16 PM
Did they have the grooves for them?
Post by: Mudhawg on December 21, 2009, 11:45:56 PM
dont think so
