4x4 Related Groups => Tech Talk => Topic started by: Zombie on December 22, 2009, 10:58:40 PM
Title: vibes from t-case
Post by: Zombie on December 22, 2009, 10:58:40 PM
I have just installed a 1 inch t-case drop to help with driveline vibes(still need to get bigger shims in the rear to get it just right.
now when I engage it into 4 high, it kinda feels like I am getting some vibes from the t-case.
my guess would be something to do with the lever not being just right because the mechanism is attached to the body and the drop changed the angles of the levers.
does this make sense?
I think I need to adapter to hook it to the tcase and not the body.
any help would be good.
thanks
steve
Title: Re: vibes from t-case
Post by: Zombie on December 24, 2009, 09:50:09 AM
anyone?
Post by: cLAY on December 24, 2009, 01:31:24 PM
There is adjustment in the linkage that might be enough.
Also the linkage bolts to the t-case and body, might have to build an adapter for the body side to drop it down. You could possibly unbolt the bracket from the body and move it down but you'd have to pull the carpet.
Get under and have a look and you'll see what I mean.
Post by: Crunch on December 27, 2009, 10:42:53 AM
I've got a bracket from my body lift that I don't need and will probably work for you
you can have it           Charlie    333-0773
