4x4 Related Groups => Tech Talk => Topic started by: yyc_tbird_sc on February 17, 2010, 11:47:40 PM
Just wondering what you guys think. I'm working on putting a new clutch into my ranger, and after a few days of being down I thought I was going to be able to get it done tonight. WRONG!!! I was given the wrong clutch master cylinder....so I just started replacing seals and everything else that needed to be done.
When I opened up the rear main seal box, I noticed that it was a speedy-sleeve version. I'm not a big fan of these things, and there is no real need for it as there is not enough wear on the crank to warrant it. What do you think? Should I just use it, and not think about it? I've never used one before, how is the sleeve secured to the crank, just RTV?
I wouldn't use the sleeve if it's not needed. I'm pretty sure brand-name speedi sleeves generally use the same seal as without the sleeve but some of the other similar products are thicker and use a special seal with a lager opening. Generally they are just an interferance fit.
find the proper seal. speedy sleeves are used for one thing only, and thats for grooved or damaged sealing surfaces.
Kinda what I thought...like I said, there was not obvious signs of wear on the crank. I took it back today, and a new one should be in my hands tomorrow. Kind of a squirt off as the truck has been on stands since Sunday evening for a clutch job....oh well, it looks like saturday should be a good day to work in the garage....
