General Forums => Chit-Chat => Topic started by: JENSSEN on March 11, 2010, 11:46:23 PM
I have a clogged clothes washer floor drain, everything drains AOK except the section of pipe that relieves the washing machine.
Help?
Last time I needed one, I just rented it from Home Depot....it was only like $8 or something
THANKS!
Hmm, I have a similar problem with my bathroom sink. I never considered renting the tool, thanks for the good advice.
You can probably buy a snake for $25.00 or so then you have one in your arsenal.
As the drain line in Question was a 4" pipe with no access hole to snake it, I rented a 2" Power snake 25' ($45.00/4Hr) from Home depot. I made a larger cutter for it and fit it through the pee trap to start working ion the drain. After 4 runs the blockage was removed and I can do laundry again. I did look into purchase but only the small drain snakes (toilets, sinks) we feasible cost wise of buy VS Rent. I also hit it with Acid 2-3 times after to make sure it won't plug up any time soon.
Jenssen 1 VS Drain 0
Want to come to Edmonton and fix mine next? ;) Only kidding, well done sir.
Check your sink pee trap,.. the U portion of the pipe below the drain in the sink, you may have an access plug in the bottom that allows you to easily clean the areas that clog.
-J
Good advice, unfortunately I just replaced that section along with the rest of the sink hardware, and it didn't solve my problem. I'm thinking the blockage is a little further down the line.
Try sulfuric acid,.. You can buy it at home Depot $5.00 just dont get it on the sink or chrome,.. use a funnel
Mmm, delicious H2SO4. Sounds good, I'll give that a try, I've got some spare time this evening.
