4x4 Related Groups => Tech Talk => Topic started by: prelude48 on March 19, 2010, 08:27:51 PM
I have a 98 cherokee witha 242 transfer case, i noticed today it stated leaking, When i looked to see where it was coming
from, it was a small hole on the left side of the shift linkage. Almost looks like there should be a plug or cap there or something.
Is anyone familiar with this? i can post a pic if need be
Thanks guys! :)
(http://i166.photobucket.com/albums/u92/clayhardock/Project%20Phoenix%20ZJ/Hybrid%20T-case%20NP242/IMG_2970_14_1_1.jpg)
Just to the left of the black tab there is a hole to access a roll pin for disassemble. It should have a rubber plug in it. You could try a glob RTV sealant but I'm not sure it would stay.
Sweet deal! Thanks
that is one shiny transfer case Clay!
Yes unfortunatly it did not last long. Its a 242 that was swapped into my ZJ but I tried to reuse the the 249 shift gate and linkages. I didn't get it setup quite right and ended stripping out some syncros and ended up with no 4wd in low range. >:(
Swapped in a 231 instead but its not all shiny.....
