		4x4 Related Groups => Tech Talk => Topic started by: bushman67 on May 08, 2010, 09:54:47 PM
				Hey guys... anyone ever get the chance to watch your t-case output shaft rotate with out a drive shaft when hoisted?
Was doing a hack & tap, and cutting the shaft with it idling in reverse to get a nice cut. And found mine oscillates a little as it rotates... however, there seems to be NO play in the shaft when pulled around.
Common? or some issue with my t-case maybe?
				That's called runout. You should put a dial indicator on it and find out how much runout there is.
Then look up the maximum allowed runout for a 231 tailshaft according to factory specs.
Hth
				it's a late model NP242, but from talking to Modern, there should be ZERO movement. Mine is probably 1/4" without even measuring it. Grrr....
				While ZERO certainly isnt correct, a 1/4 inch is way to much.
Is this 242 equipped with a magnetic speedo pick up, or a regular gear type?
