4x4 Related Groups => Tech Talk => Topic started by: JeepJeep on July 27, 2010, 05:59:51 PM
hey im just curious what other jeep vehicle/engines will have an alternator that fits a 97 tj 2.5l??? mine kicked the bucket yesterday
I believe any YJ, TJ, or XJ will fit from a 2.5L or 4.0L
I found this link...might give some of you another option.
http://www.bc4x4.com/tech/2004/jeepalt/
hey thanks for the help. im off to the junk yard tomorrow to revive the ol girl
Even a regular 4.o alt will be a significant upgrade, since 2.5's come with 65 a,p alts.
Just curious on the theory of this but instead of me installing an isolater for a second battery, what would happen if I installed a second alternator connected only to the second batt running winch, lights and my taurus fan, would the ground circuit have to be isolated as well as the positive side, or can ground circuit be shared ? I am wondering if this would be more dependable than the isolater as I have read alot of warnings that they fail often - any thoughts from electrical guys on that idea ?
I would think running two alternators would also prevent getting stuck in the woods if one failed too
I have to modify my serpentine for my york comp anyway so bracketing in the second alternator wouldn't be a big deal (I am running a second pully off the crank for this already
two alternators can share the same positive and ground as they would be in parallel not series.
OK thats good to know, so which do you think would work better, or does it matter
a separate circuit for each alternator to each battery, without an isolater
or, two alternators wired parallel with the isolater
( I was going to order a high amp but I already have both a good 65 and 90 amp, so why not use em if I can)
i have 2 batteries without an isolator and it works very well. my alt is prob a 90. if i find a 120+ at the junkyard i may get it but not a priority. 99% of the time the 2nd battery is just wasting fuel.
Hey Al!
I've got a next to new 120 Alternator that you can have for fr.....nevermind
yeah.... free with a Badger.
Nope. That was last year. This year, badgers are only available with ring and pinion sets.
You get a random live rodent with alternators now. It's a much less fragrant marketing gimmick. :D
Just to let you guys know, a 1998 Dodge 1 ton alternator will fit in a '98 Jeep TJ no mods needed, although it is much larger it will fit right in.
