4x4 Related Groups => Tech Talk => Topic started by: JackstandJohnny on July 30, 2010, 10:55:32 AM
Title: axle seals
Post by: JackstandJohnny on July 30, 2010, 10:55:32 AM
any one have some advice on how to change over a CAD D30 seal without destroying it?  i'm to lazy to pull the locker and install the one piece axle shafts, but if its gonna be a complete B@#$% to seat that CAD seal i'll just pull the locker and do the one piece conversion. (yes, i have the parts, thanks noel ;) )
Title: Re: axle seals
Post by: Grease Nipple on July 30, 2010, 11:32:37 AM
Like I said last night, even if you went with a one piece axle shaft you still have to do that seal. Unless you put it on the inside of the pumpkin like the driver’s side. But even then you will have the same problem with setting the seal right. It’s tricky. (plus you have to remove the carrier)
Use the tool I made or buy one
http://quad4x4.com/Front%20Axle%20Shaft%20Seal%20Tools.htm
This is where I got the idea from, for using the all thread and a axe head as a slide hammer.
http://dieselpowerman.tripod.com/Front%20Axle%20Tech/Front%20Axle%20Tech.htm
just need to find a socket that will fit your seal. That’s where we went wrong last night.
Post by: JackstandJohnny on July 30, 2010, 12:10:13 PM
found the solution at NAPA;  i gots myself a 2$ frost plug; same size as the seal.  just need to drill a hole in it to accept the rod.   hehehehe
time to slide on in.  see if i can skip out early
Post by: hps4evr on July 30, 2010, 06:16:49 PM
i have the exact tool you need at work.
Post by: JackstandJohnny on July 31, 2010, 05:16:53 PM
thanks heeps. we made something (thanks pook) and if it doesn't work (aka it leaks) i'll let ya know!
