4x4 Related Groups => Tech Talk => Topic started by: Knox on August 03, 2010, 01:39:43 PM
Title: Jack Stands
Post by: Knox on August 03, 2010, 01:39:43 PM
What do most people run for jack stands?
I need a pair (or two) so I've started looking around, but the review on this don't seem overly favorable, a lot of reports of the jack seizing/bending or the stands giving out.
http://www.canadiantire.ca/browse/product_detail.jsp?PRODUCT%3C%3Eprd_id=845524441888723&FOLDER%3C%3Efolder_id=1408474396672077&bmUID=1280864229717
do you guys run larger stands? ie 3 ton or 6 ton or something?
Title: Re: Jack Stands
Post by: JackstandJohnny on August 03, 2010, 02:12:52 PM
those are fine for little things, like supporting axles when doing lift kits, etc.
if you want to support the jeep completely i've got some 3 tonnes i use (again, for lift kits) and do one end at a time.  i'm sure you could support the whole vehicle off the ground with 4 3 tonnes
Post by: dac on August 03, 2010, 02:36:41 PM
I believe mine are the 3 ton ones from Walmart.  I'm not a fan of running them at or close to full height though.  I've got a stack of 4x4 blocks I use as a base for the stands.
Post by: BlackYJ on August 03, 2010, 03:01:06 PM
A stock TJ only weighes about 4,500 lbs which means the entire vehicle could be support by just 2 of those stands since they have a capacity of 4,000 lbs each.
I use 2 ton stands but usually have to put blocks underneath them to get to the right height
Post by: JackstandJohnny on August 03, 2010, 03:17:34 PM
ha, ya you can do that too. i don't like using blocks. the 3 tonnes are  alot taller and work perfect for holding a jeep without really extending them. hence i like em ;)
Post by: Knox on August 03, 2010, 03:41:43 PM
ok so for the 3 tonnes as a minimum lets say, are there brands to stay away from?
I mean I could run out to half a dozen places and buy them now, but the quality would likely be different between the places. ie PA vs CT etc
Post by: tubby on August 03, 2010, 03:47:40 PM
Buy yourself some quality jackstands and floor jack. Your life and wellbeing is at stake. Don't cheap out on ANY equipment that your life depends on. I've witnessed a few sketchy setups over the years and I've always invested in equipment that is overkill for my application. I use 3 and 6 ton jacks to fit a myriad of vehicles that I own.  I'm not a fan of using wood under a jackstand as I've seen them split . The 3 to 6 ton has a longer extended height.
Once I have a vehicle in the air, I usually give it a good nudge to see if it will move before I get under it.
HTH.
Post by: tubby on August 03, 2010, 03:55:45 PM
Jackstands don't have much in the way of moving parts. Have a peak at the welds at the very least, but you should be more than okay with 3 ton and up from CrapTire or PA.
Post by: dac on August 03, 2010, 04:21:47 PM
HTH.
There's a fella a few blocks away that has his truck camper blocked up with an assortment of wood and cinder blocks.  Whaddya think of that?   :o
Not that a camper is all that heavy but I'd expect to see it piled over one of these days.
Sarcasm aside, don't use cinder blocks.
Post by: Justink on August 03, 2010, 05:54:56 PM
We run 3 ton stands from crappy tire.  One thing to make sure of is that the base is wide enough,  We have 2 sets from CT, one with a wide base, one with a narrow, I do not trust the narrow set as it looks like it will fold under the weight of a jeep.
HTH
 Justin
Post by: Tinkerer on August 03, 2010, 07:05:47 PM
I use the 3 ton ones and love the ratchet action with handle, beats the stupid pin and retainer on my other pair.  I can put them up to the right height quickly and drop them quickly. They have been good on dirt etc. and more than tall enough so far under axles etc.  You will want something taller if you are aiming to be on the frame and go high enough to unload the suspension!  X2 on do not skimp out on safety stuff!
http://www.princessauto.com/search-products?keyword1=Jack+Stands (http://www.princessauto.com/search-products?keyword1=Jack+Stands)
Post by: Shearcon79 on August 03, 2010, 08:05:05 PM
I bought a 3.5 tonne Jack and I have (4) 6 tonne stands (for the height) and (2) 2 tonne stands for the axles.  2 of my 6 tonnes are from P.A. and 2 from Crappy Tire.  Not too worried about collapse since I went overkill.  Never trust a chunk of wood to hold up something that's rated for literally tonnes of weight...too much risk.
Post by: Rubi03 jef on August 04, 2010, 12:42:12 AM
i got four 6 ton jack stands from PA there great  and they lift high enough to reach the frame lots of support and wide base means they are stable
i also have four 2.5 jack stands for smaller stuff or just working on cars
always good to have a couple of everything .
but if your question is what brand to buy    dont waste your money on snap on   you will pay way to much for no reason
got to crappy tire or PA
Post by: Bnine on August 04, 2010, 09:54:29 AM
Greggs has nice jackstands. The PA and crappy tire types always have the internals fall apart. You can still use them, you just need set the clasp manually.
That said, I use 6 tons, and 12 tons, all of that cheap style. If I only had 1 set, it would be the 12 tons for height and comfort.
Post by: jpthing on August 04, 2010, 10:14:17 AM
Go to PA , buy the biggest or second biggest ones they have, buy them for the height, stability and beef, not 'cuz you really need a 12 ton jack stand but these are the best for the $$ IMO. Whether or not the little ones are strong enough is a moot point since they are usually not big enough. The big un's will allow stuff like tcase or tranny to be slid out from under, and will allow you to get your tires off the ground from the frame etc...I don't know if I would trust a cheap jackstand at or near its rated weight but a 12 ton stand with a two ton vehicle seems like a pretty safe bet...also I am paranoid about dropping a car on my body (kind of a reasonable fear?) so I always use a second reduntant set of jackstands if I am actually going under...one set all set up and holding the car and a second set just in case which could help shelter you in the unlikely event it did fall...I also sometimes use a big stump as a secondary backup just in case sometyhing went wrong. I know it's just paranoia but better safe than sorry. Ideally a wide range of sizes is best since they can be used to support all kinds of stuff other than the mass of the vehicle...skid plates, fuel tanks, drive shafts, etc.
Post by: frenchy on August 04, 2010, 10:32:49 AM
Sometimes you need a combination of beer kegs, wood and jack stands   ;D
(http://1.bp.blogspot.com/_zMxMhGTLxG8/S_pkil2yhjI/AAAAAAAAA6I/NnlhhkixNYQ/s1600/neckjack.jpg)
Or just use some 2x4's  :o
(http://content7.clipmarks.com/blog_cache/www.gophergas.com/img/AF441AB3-FF1A-4B84-A445-27BF9B12673C)
Post by: Rubi03 jef on August 04, 2010, 02:00:45 PM
he would need beer kegs wood and stands if he didnt buy a ford    that thing is so useless
Post by: LukeDuke on August 04, 2010, 03:24:25 PM
1, 3tonne stand will support the entire weight of your jeep. 6600lbs to be exact. So your covered for safety sake with any 3 tonne stand. It's all a matter of how high you want to go. I use 4, 6 tonne stands for PA for the hight i need plus they will hold up the 1 ton dodge tow rig too.
Post by: FiEND on August 04, 2010, 08:49:55 PM
i learned from the BEST.  12 ton jacks for me.  if i aint mooching my good friend's hoist while drinking his beers, i can at least sit up so all the mud and oil puddles i leave on my friends' garage floors doesn't fall in my eyes and mouth (which is always open and spewing some BS)
Post by: DirkB on August 05, 2010, 01:52:43 AM
I went to pick-up the 12 ton stands ... but seeing how huge these bitches are, I opted for the 6 ton ones ...
I need some urgent lifting before even thinking about getting these 12 ton stands under my Jeep :-)
Greetz ...
Post by: Spinalguy on August 05, 2010, 09:07:18 AM
i have the power fist PA 2 ton jacks.
i used 4 of them in the back alley (dirt, gravel, uneven) to support my Ram 2500 in the air. i had to take all 4 tires off.
i was NERVOUS but i pushed the truck in all directions to see if it was stable. It worked.
i would do it again.
Post by: Shearcon79 on August 05, 2010, 05:53:49 PM
Hairless!!!  Not worth the risk!
Post by: Spinalguy on August 05, 2010, 06:53:45 PM
meh, as i said i pushed that truck and it never budged.
Post by: i_go_commando on August 05, 2010, 08:12:27 PM
once i get the vehicle up in the air i throw anything else i have under the frame as well. like rims blocks ect
the diferences in metal thickness is a big differnce. a vertical lift is one thing but say someethings shifts a bit when your yanking on rusty bolts. i had a cheep jack stand colapse on me when the axle that was on it caused it to twist. the jeep fell hard. i still have those jacks stands but i straigtened and guseted em. it has been recomended to mey to weld or bolt a plate of steel on the bottom for more stability. also go the biggest you can justify. you like the extra heigth.
Post by: jpthing on August 05, 2010, 10:12:18 PM
Sudden catestrophic failure seldom gives warning...I'm sure that this would work but it would not be "safe" by a proper definition, although I'm sure the guy with the kegs would consider it top notch. Pushing it from side to side tests stability not weight bearing abilty. Just for changing tires I guess you could probably overload the jackstands a fair bit (I wouldn't) but I personnally wouldn't get under a vehicle and start reefing on stuff unless the jacks were at least rated for double the weight of the vehicle. It's not the liklihood of the failure, it's the result of the (unlikely) failure to consider.  Also what if the jackstands are compromised by overloading now and may not be as safe even with their proper load?
There is also the age and condition of the stands to consider...
Post by: JackstandJohnny on August 05, 2010, 10:32:54 PM
i like the jackstands at pick'n pull;  you know, a couple rims welded together; they seem to be plenty strong and people wrench under them all the time...........
Post by: jpthing on August 05, 2010, 10:44:22 PM
the range of height adjustment on those is a little lacking though i'd say
Post by: dunl on August 06, 2010, 12:14:21 AM
Once I have the rig up in the air,  I shake the crap out of it to make sure it is stable.  If it isn't, I redo it again.
Post by: Rubi03 jef on August 06, 2010, 04:45:39 AM
this is practiced by even the best mechanics .. even on the hoists .
they get there legs lift check again lift a few inchs off the ground and then they shake the crap out of the car/truck  while only being off the ground a few inchs if it moves to much set down and restart
its safe and you know you did all that you could to make sure it was stable
and like the guy above wrote    through other things under the frame .. when i take my tires off i toss them under the jeep or other automobile for 2 reason . if it falls it doesnt hit the ground and 2 now your no longer triping over your tires :)
Post by: Spinalguy on August 06, 2010, 12:28:47 PM
Using 2 ton jacks on 4 corners is 8 tons. Unless you are holding a garbage truck... ::)
Post by: XJSteve on August 06, 2010, 09:00:25 PM
I completely agree with over purchase. A few years ago I had 4 2 ton stands under an MGB with its engine and tranny out and was pulling at the heating system to remove from the firewall. The entire vehicle ended-up around me and on the ground (don't think for a second that you have any type of warning). It bent the base of 2 of the stands. I know you're all thinking that I was pulling with a winch or something of substance but I was simply torquing the box off. Needless to say I now buy the strongest stands I can find reasonably (6 or 12 ton) with the widest base. I've also found that part of the problem is that independent suspensions add a real challenge in finding the right location to stabilize the axle stand on given there is often no real "axle" to support from. Given there are standards in Canada for claims on weight capabilities, I don't think it really matters which brand but rather the weight limit that determines which one to buy.
Post by: Spinalguy on August 06, 2010, 10:06:56 PM
Agreed. Take the best measures to be safe. Nothing wrong with overkill.
My point is that 2 ton jacks can work fine as long as the job they are being used for is appropriate.
Post by: Sugarphreak on August 06, 2010, 11:06:42 PM
I got these as well, I use them for my truck when I need to do work ... more height and more stable, plus the price is right.
http://www.princessauto.com/garage/repair-equipment/lifting-devices/1090547-6-ton-heavy-duty-jack-stands
Post by: jpthing on August 08, 2010, 12:35:24 PM
I've always wondered about jackstand ratings, the wording is a little ambiguous...I think they usually state that they can support X number of pounds "in pairs"...So is this the actual weight a pair can safely support or the weight of the vehicle that the pair can support half of? And what weight can one support? Is This a max or safe working load?
I agree that by the ratings it's total overkill, but I also think that in general with cheap chinese stuff limiting yourself to half the rating is probably a good rule of thumb...
When evaluating risk it is equally important to consider how bad the risk outcome is in addition to considering what the likelihood of the risk event occuring is.
I'm not trying to give you a lecture, it's just that this is one area where you don't ever want to have a problem...I would sooner disregard the advice of the "experts" when it comes to proper belt tension and the use of belt dressing than I would when it comes to overloading of jack stands. I can deal with having a belt wear out or become contaminated by foreign matter...I hope I never have to deal with a failed jackstand.
I would lower my vehicle onto blocks of wood before I would overload a cheap jackstand.
FWIW I would guess that the weight of a garbage truck is at least 30,000 pounds empty...you may need a little more that those two tonners, and besides they are likely too short. :-)
Post by: morerpmfred on August 08, 2010, 01:16:21 PM
 I would not use wood blocks . they are not rated . Seen a set of wood blocks fail on the farm as a teenager . the results where not pretty for the person working underneath. By looking at the blocks you would think they could hold up a d9 cat.  Use wood blocks for chalking the wheels
Post by: LLYJ on August 09, 2010, 10:44:33 AM
I use 3 ton canadian tire type jacks with the racheting riser.  I'll never use pins again, I hate those risky moments aligning the jack, and the rachet reduces that time.  I also have a couple odd-ball screw collar jacks - I wouldn't put more than a drive line on them but that said they are the most useful tool I have ever had for lining up heavy parts within a millimeters accuracy.
I do use blocks and wood for bases - but guess it comes down to measuring risk.  The closest I have come to toppling my jeep off the jacks was while wrestling the snot out of a siezed in front hub - temps that day got pretty hot and before I knew it the jeep started to lean.  Luckily, I noticed the jacks sinking into the pavement before it fell.  I think that's a point worth mentioning, If your working on pavement instead of concrete use a steel plate or suitable wood for blocking.  I also almost always try to leave the opposite end wheels on which makes it almost impossible for it to tip off sideways.
We use wood blocking for both plows and tandems, and the plow units alone weigh more than a typical jeep, and the whole unit together is about 30 tonnes - I think the key point here is not to use crap wood - there are three woods that I use.  I have a couple 3"x12"x12" douglas fir raw cut slabs for bases, these are cut off leftovers from the wood we use to deck our heavy equipment lowboy hauler deck (which has no trouble supporting a D6 ).  I also use blocks constructed (again cut-off leftovers) from guardrail posts lag-bolted together. To ensure a perfectly flat surface I plate the top with recycled highway sign board - this stuff has so much epoxy in it, it wont delam or crack after 20 years of exposure and I have zero concern of it ever splitting as I harvest newer peices from signs taken down in accidents. I also pilot the screws holding the deck and have one for about every 4 " squared area - despite my confidence in the wood that I use, I still take the trouble to toss a secondary block under axles just in case.  ( I saw a "faces of death" tape that had a guy die from an axle pinning and crushing his leg when I was in high school, I remember that tape everytime I jack up).
I guess the safest thing to do would be to use a couple steel 3/8 to 1/2 plates if a concrete floor isn't available,  and with anything, redundancy, is important (extra safety blocks always)
Post by: cLAY on August 09, 2010, 12:42:17 PM
I had my jeep fall off stands once while trying to swap axles on a gravel parking pad.  It was in my younger more desperate days before I had nice tools and a garage. Fortunatly it went slow and I just stood clear and let it go.
I find that I like the bigger beefier jacks simply for their wider footprint. More stable and less likely to sink into soft ground. I also tend to throw a tire or two under the frame and with a 36X13.5 tire that makes quite a good safty.
Quick note on jacks, don't trust them. Ever! Last year a guy at work was using a cheap mastercraft trolley jack set from Canadian Tire to do the brakes on his wife's Saturn. He was having trouble gettign the jack stand where he wanted it so he slid under the car to place it just right. The jack picked that exact moment to blow a seal and drop the car on him. Fortunatly he was able twist out and only suffered bruised ribs but was off work for two days.
When he phoned Canadian Tire to complain(it was a brand new set), they gave him a 1-800 number to call to submitt a claim. Apparently this happens all the time and they have a special line to deal with it. Got a small settlement in the end to boot. He's a red seal mechanic and felt pretty stupid. Said he'd never do that at work and couldn't figure out what possed him to do that at home....
Post by: FiEND on August 09, 2010, 12:53:50 PM
mine only tried to fall over once.  i had put the front axle on two 6 ton PA stands.  was lifting the back to put the other 2 stands under the rear axle and the front started to tip over forwards.  almost went out the garage door but i steadied it pulling on the floor jack.
Post by: Shearcon79 on August 09, 2010, 08:14:23 PM
I've been there.  Realized it's not worth using a lesser jack.  The wheels need to be able to move on the jack while you are lifting the vehicle to prevent the vehicle from shift it's weight.  If you are using a bottle jack it will lift straight up but a floor jack rolls to keep the vehicle in the same spot.
Post by: Knox on September 17, 2010, 11:39:19 AM
as a follow up
http://www.canadiantire.ca/browse/product_detail.jsp?PRODUCT%3C%3Eprd_id=845524442952215&bmUID=1284744812483#BVRRWidgetID
these are on sale this week at Crappy Tire,
Certified 3-Ton Jack Kit
Jack + 2 Jack Stands
Post by: jpthing on September 19, 2010, 10:13:43 PM
as a follow up
Looks like a good enough setup for the $$ , I guess, but I would way rather get that kinda stuff at Princess Auto...They offer a no questions asked satisfaction guarantee that doesn't even require you to have the receipt...so when that cheap jack starts leaking in 2 yrs, you can just go get a new one for free...just my 3 cents. Costco has more or less the same policy...these two stores get a lot of my business just on the strength of their return policies, you don't have to worry, buy it, try it, if it sucks, return it, if it breaks get your $$ back or a new one...no worries about whether it's good or not...if it's not, back it goes.
Post by: frenchy on September 19, 2010, 10:54:05 PM
... you don't have to worry, buy it, try it, if it sucks, return it, if it breaks get your $$ back or a new one...no worries about whether it's good or not...if it's not, back it goes.
Maybe it's just the way you worded your loco lyrical mastermind response, but it seems you value the return policy more then your own life?
Post by: raf2379 on September 20, 2010, 12:06:34 AM
i've been using the 6Ton PA stands for over 2 years and havent had any trouble with them, next purchase is the 14 Ton jack stands from PA so that I can raise the jeep by the body frame up higher than the 6 ton extend. its never a good idea to crawl under a car with only a jack supporting the weight of the vechicle.
Post by: jpthing on September 23, 2010, 12:54:14 PM
I'm pretty sure both CT and PA jacks, stands etc. are for the most part made by the same company, called Shanghai Catic. I would not use any product I didn't trust...jackstands of course last almost forever, jacks generally do not, what with the seals and valves and stuff to fail. Interestingly enough, both PA and Costco do not require there to be a fault in the product to return... so you could return your stuff because "I should have bought bigger ones" or "because I bought a new truck and the colours don't match" or whatever...I'm not saying I would return a product for these types of reasons, but it is nice to buy with confidence, knowing that if it doesn't make (and keep) you happy, back it goes...unlike Canadian Tire, where if you buy certain items (such as an air compressor) and bring it back THE SAME DAY with a receipt because it has a clear defect (such as a bad weld in the tank that leaks) they will tell you that the policy manual states that all defective air compressors need to be brought to the service depot for repair. This actually happened to a friend of mine, who actually bvought the air compressor because he needed it for woirk the next day...lucky for him they agreed to "help him out" and exchange it, but personnally I would rather shop where you can buy with confidence...I still buy lots of stuff at CT, like oil, filters, etc, but not big ticket things that can break, when there are other options.
