4x4 Related Groups => Tech Talk => Topic started by: keener on August 29, 2010, 08:41:18 PM
Title: TJ OME Lift
Post by: keener on August 29, 2010, 08:41:18 PM
Has
any one experienced interference between the lower part of the rear shock body and the spring bucket ?
What did you do about it ?
Title: Re: TJ OME Lift
Post by: ornamental on August 29, 2010, 09:50:48 PM
i think you can invert the shock and or cut the overlapping shield on the shock.   it a  gas shock right?
Post by: cuzican on August 29, 2010, 10:21:24 PM
Extend the mounting bracket on the diff.
I believe there are kits you can buy or you can weld on some homemade extensions. I made extensions out of 2x2 and welded them on.
