4x4 Related Groups => Tech Talk => Topic started by: nobody on October 04, 2010, 06:04:47 PM
Are the pinion bearings hard to change in a 95 yj
Uhh what was wrong with the answer in here?
http://forum.calgaryjeep.com/index.php?topic=20060.0
no that was all good sorry bout that one..........what I was wanting to ask after i take drive shaft off then the yoke nut can the bearing be taken out or does a guy need to pull axles
you need to pull the axles and the innards of the pumpkin then brass punch/hammer out the old races, brass punch/tap in new ones. this may affect preload. some diffs use crush sleeves so lots of torque required. also need new pinion nut and seal. it isn't a lot of work if you have the tools and done it before. if not, can take a good amount of time.
well if I have it all apart maybe i will put in a posi thanks for your help pal how does one become a member of this club I mean more then on here and where does one pay his dues?
http://forum.calgaryjeep.com/index.php?topic=8466.0
