4x4 Related Groups => Tech Talk => Topic started by: Strongbad on November 02, 2010, 12:47:22 PM
Just looking for people's experience, and opinions.
I Would like to put a 1 inch lift on my TJ, and it seems there are a lot of different brands, with different types of "pucks" .
Ones that sit on top of the rubber, and ones that replace the rubber bushing entirely.
Just wondering if people have had good \ bad experiences with certain ones. IE - excessive body roll, body slipping on the pucks, etc.
Thanks everyone.
M
Daystar, the only body lift i would ever use or recommend. it replaces the whole body mount minus the top metal piece.
http://www.daystarweb.com/productdetail.php?productID=319
little more expensive then other body lifts but is well worth it.
Savvy Offroad
Designed by one of the best minds in the jeep world who has been involved in the design of some of the best products in the jeep world MrBlaine!
Everything he puts to market has been tested in some of the most hardcore offroad environments there are the Hammers
http://shop.savvyoffroad.com/product.sc?productId=57&categoryId=16 (http://shop.savvyoffroad.com/product.sc?productId=57&categoryId=16)
Thanks Gents.
M.
I don't know about everyone else, but I'm leaning towards an aluminum-based 'pucks' over the polyurethane. Just seems like it would suspend the weight of the tub better over time and won't break/flex/crack out.
It'd be a good idea (for your fan shroud, etc) to consider a motor mount and t-case lift and maybe even a SYE while you're at it.
HTH!
I ran a Teraflex Aluminum BL on my first TJ and it worked fine. On the rest of my TJ's, I made them out of poly ethylene...strong as hell and cheap to make.
