4x4 Related Groups => Tech Talk => Topic started by: 535i on March 09, 2006, 09:31:28 AM
Just did a 3" Sky Jacker on my 98 XJ, still have a bit of a sag in the rear. Anybody familiar with a minor rear lift.
Do a shackle, XJ leafs packs don't stand up well to blocks.
Yeah, makes sense.
put a add-a-leaf in
helps the old leafs out also
put a add-a-leaf in
Have new rear springs
put a add-a-leaf in
It will make your ride stiffer but will get rid of the sag.
You might think your XJ is sagging in the back but it's might just be the wheel wells that are higher in the front. Check it out. Mesure the height from the body line not from the wheel well.
I opted for the shakle myself. I didn't want to give up the little flexibility I had in my rear leaf springs.
I added in a 2" shakle in the rear and a 1.75" spacer in the front on my 3" lift kit. You end up having close to five inch lift for not too much extra $$$. You will have to change your front shocks for a 3"-6" travel ones (the rear one will be ok). I didn't drop my T-case either and I just had a little drive shaft vibration. It was bearly noticable.
That's what I did .. i hope it helps (I have a 99XJ).
Cheers,
I did what SwampSinger said, measure, because I though that mine was sagging but it was the cut of the wheel wells. I threw a couple springs from my old leaf pack in the new one to make the rear end sit up so the wheel wells were the same and didn't notice the stiffer ride.
Hey guys thatnks for the info. Both great Ideas. Think I will look into the Shackles and Front spacer, crappy thing is I have less than 500kms on my 3" skyjacker shocks now :cry:
Oh well.
