		4x4 Related Groups => Tech Talk => Topic started by: apeman on January 05, 2011, 01:05:04 PM
				Anyone know if the thick cut D44 gears from a rubicon will fit a standard D44 housing ? Just wondering if there will be any problems come set up time?
				The thicker gears need to be on a 373 and down carrier, and use 7/16 bolts instead of 3/8 like regular 44's. If using a regular 44 carrier, you have to open up the ring gear mounting holes to 7/16.
Other then that, same as everything else.
hth
