4x4 Related Groups => Tech Talk => Topic started by: Rubi03 jef on January 06, 2011, 06:12:55 PM
ok so heres my new problem
i changed out my fenders to flat fenders
now wiring new flashers and corner lights and i have a problem . i lost my flasher and 4 ways
they will not work they dont even show up on the dash .. is there a relay some where i checked all the fuses and there all good the lights light up but they do not flash
and on the dash nothing shows up
if there is a relay where would i find it
thanks
Are the new lights LED?
if so or not you may have to switch from a mechanical flasher relay to a electronic one. The new lights don't have enough resistance to build up heat and cause the mechanical relay to switch from side to side (flash).
You have to make sure you leave all the bulbs in their recepticles. Just stuff the extra ones into the grill.
ya i found that out .. but where is the relay for the flashers its it in the fuse box under the hood or in the glove box
cuz my main issue is i think i may have shorted the wires because i had flashers earlier today but now i on my dash nothing lights up
but the lights are lit
On top of the steering column under the plastic cover and to the right of the hazard button.
