4x4 Related Groups => Tech Talk => Topic started by: Traktor on March 03, 2011, 04:41:34 PM
Title: Water Pump and...
Post by: Traktor on March 03, 2011, 04:41:34 PM
I need to change the water pump on my 4.0 YJ. I could hear the bearings howling occasionally and now the fan is wobbly. I know I need to change the pump but I'm unsure what else, my crappy Haynes doesn't explain it very well. Do I also have to change the fan clutch? Or is the shaft on the new pump enough to solve that issue?
Also, is there anything else I should do while I'm in there?
Title: Re: Water Pump and...
Post by: BlackYJ on March 04, 2011, 07:21:27 AM
The water pump is pretty easy, but you have just to remove a lot of stuff to get at it.  As for the clutch fan, does the fan spin freely with the engine off?  If it does not spin then it is time for a new one
Post by: Traktor on March 04, 2011, 08:40:34 AM
It seems like the clutch and everything is working properly, it's just the wobbley fan that I want to make sure is fixed. Will that be repaired once I put the new water pump in? I guess what I'm asking is, does the shaft on the new water pump fit into the fan and clutch and resolve any wobbley issues?
Thanks for the reply,
Tim
Post by: fug on March 04, 2011, 09:25:28 AM
Yep... a new pump should take care of the play in the shaft you are seeing.
Post by: Traktor on March 04, 2011, 11:27:04 AM
Good news. Thanks guys.
