4x4 Related Groups => Tech Talk => Topic started by: fug on March 22, 2006, 09:06:11 AM
Title: TJ transfercase skid plate mounting holes question
Post by: fug on March 22, 2006, 09:06:11 AM
It's my understanding that in 03 the mounting holes for the TJ TC case skid plate were relocated.  Which means if you're buying a Rubicon Express LA skid plate the 97-02 version is slightly different than the 03+ version.
Has anyone every modified the older style to fit on a newer TJ?  The long arm kit I'm buying is installed on 98 so it's got the older style skid plate and I'm just wondering how difficult it is to modify to fit on an 04.
Fug
Post by: Bnine on March 23, 2006, 11:51:13 AM
I imagine its just a bunch of drilling.
Mount all the arms up to the axle
Push the plate up
Mount the arms on it
Bolt the t-case up
mark where the plate holes are on the frame.
Drop it all
Measure mark distance from stock holes
Drill the plate to match, using the marked holes to stock holes center to center distance.
Something along those lines should work.
Or you can drill the frame to match the old style skid. Drill right through, use a spreader plate on top of the frame and attach everything with about 4" long bolts.
One of those should do the trick.
