4x4 Related Groups => Tech Talk => Topic started by: M T on April 25, 2011, 03:57:52 PM
I am replacing the u-joints on my front shaft. I bought some new u-joints today, but am wondering if I will be able to grease them once I have the double cardan joint put back together? I am worried I won't be able to get the grease gun in between the double cardan and pump the joint full?
picture of the double cardan http://www.stu-offroad.com/axle/driveshaft/ds-17.jpg
picture of the type of u-joint http://www.performanceonline.com.au/images/T/PCN-316.jpg
answers?
That nipple might rip off when your CV will flex (?) and you will not get the grease gun to fit in...
solution:
use an inward nipple and this adaptor
(http://images.bizrate.com/resize?sq=140&uid=2008552717)
I have that type of u-joint on my double-carden... so far, no issues. Can be a bit of a pain to grease, granted. Just jack the wheels off the ground, and rotate the tires with your foot as needed.
Have you had issues with that type of u-joint, Dom?
It's not the u-joint that Dom is referring to. He's talking about the grease fitting. I use the ones that need the needle adapter for the grease gun, and it makes access to them easier in a double-cardan application.
I went to Pat's Driveline and got the 'right' stuff. Thanks guys.
Trevor only thinks about boobies... he was blinded my by "inward nipple" comment ;D
LOL!!! True.
You should see the look my wife gives me when I say "Nice zerks".
