General Forums => Chit-Chat => Topic started by: Jrama on February 20, 2012, 06:13:24 PM
Title: TJ Sub-woofer Replacement?
Post by: Jrama on February 20, 2012, 06:13:24 PM
I blew the stock woofer in my TJ, any good place to find a replacement? To those who may not know a 6.5" shallow mount 2-ohm sub is not the easiest speaker to come across. Or better yet.....any easy-ish worthwhile upgrades? I have little experience with car stereos, but any suggestions that would point me in the right direction would be good.
Title: Re: TJ Sub-woofer Replacement?
Post by: BUKI on February 20, 2012, 06:20:12 PM
2 words tang band. You tube those. Ridiculous amounts of bass from those little cones. Only if you want something that will go in the stock location.  It would be an upgrade.
Post by: BUKI on February 20, 2012, 06:21:49 PM
Whichever way you go I can help out if you need
Post by: X-Treme on February 20, 2012, 10:20:57 PM
Googled tang band, and they don't make a 2 ohm speaker.
Post by: FiEND on February 20, 2012, 10:36:29 PM
ebay $95 shipped (http://www.ebay.ca/itm/KICKER-10-CVT65-2-6-1-2-CompVT-SHALLOW-MOUNT-SUB-WOOFER-CVT-2-OHM-6-5-10CVT652-/360436096558?pt=Car_Subwoofers_Enclosures&hash=item53ebaa5e2e)
Post by: BUKI on February 21, 2012, 02:36:37 PM
Well that sucks. I didn't think that it was 2 ohm
Post by: Jrama on February 21, 2012, 02:49:44 PM
Yeah the eBay one was my top choice, I was just wondering if any other Wrangler owners got creative and found something local that works. Quadratec also has direct OEM replacement, but..meh
Post by: BUKI on February 21, 2012, 03:09:30 PM
Select increments had some cool stuff. But nothing that will fit in the stock location
Post by: 03Jeeper on February 21, 2012, 04:10:58 PM
I bought a replacement last year off ebay for a good price. It was made by Pyramid. Ill get the model number when i get home for you.
The sub is a cheap oem replacement, sounds good too.
Post by: Jrama on February 21, 2012, 04:27:36 PM
Hmmmm....I just pulled the trigger on the ebay one......oh well,
 I'd think they'd sound about the same too, its not like the enclosure in the Jeep is any good.
Post by: X-Treme on February 21, 2012, 07:44:05 PM
Did you go with the Kicker one? If so, I'd like to know how the install/fit goes, as well as the sound. Tia
Post by: Jrama on February 29, 2012, 05:19:19 PM
I ordered the Kicker, as a matter of fact I ordered directly from the link posted earlier in this thread. And it Just arrived today!
I'll go install it and I'll let you know how it goes.
Post by: X-Treme on February 29, 2012, 09:44:51 PM
Awesome!! Looking forward to your "review".
Post by: Jrama on February 29, 2012, 10:52:26 PM
Well the install was actually pretty easy, the wiring was very easy and it sounds better than stock, Its not amazing but a definite improvement.
Hardest part was clearing out the housing to make room for the larger speaker. I took some tin snips and went to town, the plastic would just shatter when cut....sooo it was kind of fun.
Wiring involved attaching the brown wire to the negative terminal on the speaker and attaching the grey to the positive. I had to cut off the little clips on the wires, strip them and then attach them to the speaker. Speaker had these neat little clips so it was a breeze to hook it up. There were two wires (black,red) which I tried attaching..didn't work, left them unattached.
OEM Speaker still wired in
(http://i977.photobucket.com/albums/ae257/Jamalrama/IMG_0880.jpg)
Kicker wired in
(http://i977.photobucket.com/albums/ae257/Jamalrama/IMG_0881.jpg)
Drilled out some new holes for the original screws and after a few test fits it sat flush. Screwed back in, re-installed the center console and boom...new woofer.
Post by: Toyman on March 01, 2012, 05:34:22 PM
Thanks for the write up.  I was thinking of going this route myself, but I may end up doing a custom enclosure with a JL 8" of some sort, a 8W7 would be nice to fit in!
Post by: Jrama on March 01, 2012, 05:51:14 PM
My whole deal with a "close" to direct replacement was
1. Fairly simple to install
2. Didn't take up any extra room, in a TJ loaded with spare parts and camping gear this is pretty important...well actually just in a TJ. This is very important
3. I was also concerned that a larger woofer might overpower the rest of the system? Then I would have to spend more money than I ever wanted to on a well rounded system.
