4x4 Related Groups => Tech Talk => Topic started by: anjoxj98 on July 14, 2012, 01:26:15 PM
Title: Need some advices to lift my XJ 0.75 or 1" more
Post by: anjoxj98 on July 14, 2012, 01:26:15 PM
Hi ,i need some help ,  i have a cherokee Xj 98 .. she is actually lift 3" with a rusty off road suspension
but i want to lift it a little higher without change stock parts , i want 1 more inch but if i have to change anything i  m open to 0.75"  . if i have to change something with  4" please tell me .
 Also i would like to know what size if tires i can put on it with 3.75" or 4"  lift
i would appreciate any advice , thanks
Title: Re: Need some advices to lift my XJ 0.75 or 1" more
Post by: tubby on July 14, 2012, 09:25:55 PM
Not a difficult or expensive undertaking.
Front- stack another coil spring isolator over the coil.
Rear- el-cheapo block under the leaf springs .
You can comfortably run 31x10.5x15" tires with 3-4" of lift. 33" tires are possible if you're okay with trimming the body.
Post by: anjoxj98 on July 14, 2012, 11:11:42 PM
 thats what i going to do , put some spacers ..but my question is , after I lift the truck more than 3" what I have to change and if I really have to do it .  For example I would like to lift it  4" or 4.5" but I don't know if I really need to change the track bar and lower control arms .. Also I'm not sure if I want to trim because that's my daily. Drive and I don't want to go to crazy he he.  :D .. i want she look nice and have a acceptable performance when i go off roading     ;D
Post by: apeman on July 14, 2012, 11:22:36 PM
You can buy 3/4" spacers for the front and use mj shackles in the rear for an extra 3/4"
As Tubby says running 31's is most likely.  Upgrading trackbar and lca's isn't a bad idea, and watch for any vibes from the driveshafts.
