4x4 Related Groups => Tech Talk => Topic started by: jeeeep on September 02, 2012, 06:25:23 PM
I have a 97 TJ 4.0L and I need two sensors the ones on the throttle body the idle/air on valve cover side and the one on the firewall side please help this thing is going to drive me insane if I dont get this thing fixed it might accidently start on fire back in the bush lol
you are wanting to know the names? otherwise check try the forsale forums.
Ok. So from the sounds of this and the other post you have made you are really green at wrenching/jeeps. No biggie we all have to start some where. Now you haven't in any post I have read given your symptoms of what is happening. Is it bucking/crazy hesitation. Idle all over the place? You can remove the t body with the 4 bolts on top, remove t cable/kickdown cable, both harnesses and voila it should come out as a unit. Then you can remove the sensors (torx a 15 or 20) clean your t body and sensors/replace them. A tps can be had at parts source for 55 (yj price, tjs are different wiring is opposite). Iac is more, but I wouldn't throw parts at it unless you know your problem. Which brings me to codes, have any? Have you done the 3 key , on off three times thingy? Or an obd2 scanner?
well I am a HD mechanic but have never worked on a jeep in my life so its all kinda new in a way lol... so it wants to stall out all the time and is very hesitent when your stepping on the gas
I still say tps but that would have thrown a code
yes and it throws a po-132 code... well we took the throttle body off cleaned the inside, the idle/air put it back together works decent now still hesitates alot but no stalling so its getting better
Right-o...if it's still hesitating I would seriously look at replacing your O2 sensors. They can fail and not throw codes.
Mine was a stuttering, smoking, bucking pile of crap until I replaced them...Smooth as silk now.
