4x4 Related Groups => Tech Talk => Topic started by: apex on May 29, 2006, 02:16:18 PM
Title: rear driveshaft lengths
Post by: apex on May 29, 2006, 02:16:18 PM
sorry if this sounds like a noOb question,
is there difference in driveshaft lengths for TJ's with the D35 and those with D44? I've got a line of D44 just wonding if I have to budget for a new DS.
input apreciated
Post by: BlackYJ on May 29, 2006, 02:32:40 PM
It might be a little shorter, but nothing a grinder and a welder can't fix.  Plus your slip yoke would probably take up some of the slack.
Post by: apex on May 29, 2006, 02:43:03 PM
phanks scott
Post by: Bnine on May 29, 2006, 07:12:56 PM
d44 be an inch or so shorter.
Bad for a lifted rig with a d35. Lifting already pulls the slipyoke further out of the tailshaft.
Post by: apex on May 30, 2006, 09:01:56 AM
Thanks Bill. What if I score the DS from the 44 setup, I should be fine then right? My best bet would be the 44 with SYE and a new DS anyways right?
Hey Bill, can you do pinion seals? my rear needs some attention. I understand it is fairly straight forward fix, but with some very specific torque settings.
Post by: Bnine on May 30, 2006, 09:32:18 AM
Yeah we can do that. Just give  me a holler.
If you get a D44, the stock D35 shaft should work out just right with the lift you have.
You just have to make sure that it doesnt bottom out on compression.
The sye is definately the route to go, but lots of dollars by the time you do the tailshaft and new driveshaft. You should be able to get what you have working until you can SYE.
Post by: Da_chopper on May 30, 2006, 12:46:20 PM
I could probably part with my stock Rubicon DS.  It has about 12000km on it.
PM me if you are interested.
Post by: apex on May 30, 2006, 02:55:14 PM
thanks for the offer. Unfortunately this deal is lined up for late in the fall. getting a D30 and D44 with 4.10's for a smoking deal if it goes thru. straight swap will be easiest way I can regear and get a d44 to boot.
Post by: BlackYJ on May 30, 2006, 03:31:28 PM
Quote from: "apex"
Oh cmon now, 33s with 3.07s is a great system
Post by: apex on May 31, 2006, 07:38:53 AM
now now scott. no need to get condescending of other peoples setup.  Need I remind you your headlights are square?
I gotta use what I have until I can get new stuff.
Post by: BlackYJ on May 31, 2006, 08:45:33 AM
Hey 4 squirrels and 33s is not much better
