4x4 Related Groups => Tech Talk => Topic started by: 4PLAYZJ on November 28, 2013, 06:16:29 PM
Title: Ford HP 44 and 9"
Post by: 4PLAYZJ on November 28, 2013, 06:16:29 PM
Can you guys tell me the pros and cons for these axles. Ford HP Dana 44 and matched 9" from a 1979 f150.
Title: Re: Ford HP 44 and 9"
Post by: Fredduck on November 28, 2013, 07:06:36 PM
The cast diamonds on the 44.
It is a serious weak point
You can't weld to them and the tube doesn't go all the way through
This is the most through dana 44 page there is
http://77cj.littlekeylime.com/web_rs44.html
Try and find a 44 from a 3/4 ton
The 9" is good and strong but a low pinion may cause drive shaft issues
Post by: 4PLAYZJ on November 28, 2013, 07:19:31 PM
I was planning on getting some 2.75 x. 500" Dom and replacing the tubes and trussing it.  To solve the cast issue. I'm concerned about the 297 joints behind a 5.9.
Post by: Fredduck on November 28, 2013, 07:26:18 PM
I have the same joints with the 3.9 Cummins.
I estimate torque of that engine around 400 ft/lb's
I've only spit out 1 or 2 joints  :o
Post by: 4PLAYZJ on November 30, 2013, 03:20:05 PM
Think I will go a different way. Found some AAM axles I will use.
